Smarter Coffee & iKettle 2.0 Topic is solved
trixwood
Post by trixwood »
iKettle 2.0 & Smarter Coffee Interface for Domoticz
Source & guide:
https://github.com/Tristan79/iBrew
Screen Shot 2016-08-16 at 01.43.57.png (90.21 KiB) Viewed 5800 times
trixwood
Re: Smarter Coffee & iKettle 2.0
Post by trixwood »
Updated iBrew with trigger support & mini guide to integrate the ikettle and the smarter coffee in domoticz :-)
trixwood
Post by trixwood »
Added windows support. No need to fiddle around with python or packages. Just use the exe ;-)
trixwood
Post by trixwood »
Setting up iBrew for domoticz is very simple!
* 10.0.0.99 ip of iKettle!
* user:[email protected]:8080 domoticz connection string
ibrew domoticz user:[email protected]:8080 10.0.0.99
It will set up all your sensors automatically!
See github for more info...
corederoma82
Post by corederoma82 »
hi i have a question that I don't understood.....but the smarter coffee is functioning with domoticz?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
trixwood
Post by trixwood »
Well, yeah! With a little bit of work... care and love, and probably some coffee :-)
All the sensors/values can be added with the previous command and and are updated with the ibrew server...
It creates for you the hardware, and the sensors... and the ibrew server updates them when changed in any way...
That is the automatic reading part..
For the control bit...
You still have to add actions manually to virtual switches in domoticz...
and calling ibrew rest api to switch things on/off, set cups etc...
so it needs a little tweaking...
Just add a new virtual switch
action: off http://ibrew_ip:2080/api/kettle_ip/stop
action on: http://ibrew_ip:2080/api/kettle_ip/start
and make
that a Sub/Slave of the busy motion sensor...
That should work... I haven't got around the test and map out, the control bit... not at home atm. :)
If you start the ibrew server have a look this page:
http://hostibrew:2080/info/api
it contains all the commands possible, plus you can test them there:-)
So it's semi-automatic...
corederoma82
trixwood wrote: All the sensors/values can be added with the previous command and and are updated with the ibrew server...
Hi, thanks for your answer, but whick commands?
trixwood
Post by trixwood »
The reading part of the sensors use the above post:
http://domoticz.com/forum/viewtopic.php ... 77#p110655
after that run to run the server...
ibrew events web
Any bugs report on github :-)
or look on the github page,,,
corederoma82
But it's possible install it on Domoticz running on Windows?
trixwood
Post by trixwood »
yeah! :-) there is a windows package... and you can run the setup from there (running ibrew.exe) :D
corederoma82
windows package is not more available.....
pazzje
Post by pazzje »
I know, i am looking to for a copy... Who has one?
