Appropriate door sensor for electricty disc meter
Posted: Wednesday 10 August 2016 19:34
Hello Fellow Member of Domoticz,
I'm looking to install Domoticz on RaspberryPI to monitor Gas/Water/Electricity consumption with wireless capabilites (433Mhz).
At the moment, I know I need a reed/magnetic sensor for the gas meter, and infrared emitter/sensor for my electricity rotary disc meter.
I intend to use an RFXtrx433E USB HA controller (Transceiver and Receiver) to receive 433Mhz signals from the sensors.
But after a bit of searching, It has come to my attention that HomeEasy,Chacon,KlikAanKlikUit,NEXA... door sensors that use "AC" signal burst, are best not to implement in an home automation system. This is because they send a repetitive signal once sensor is triggered, which causes the RFXtrx to stop transmitting for 5 seconds. Whereas KAKU, HomeEasy, Chacon, NEXA... sensors with address code wheels (A-P/1-16) are ARC types and don't behave the same, so they don't block the Rfxtrx.
More info: http://www.domoticaforum.eu/viewtopic.php?f=27&t=7337
viewtopic.php?f=14&t=4995&p=37991&hilit ... sor#p37991
So if I'm not mistaken, this is a problem only if you actually use these door sensor as door sensors and would like to send a signal to a light or what ever as soon as the door opens, right?
But all I want to do is to use kaku/chacon... door sensors to monitor my gaz/electricty meters using the reed switch. At this stage I will have nothing else than two 433mhz door sensors only. Maybe three if I work out the how to for the water meter.
Does this configuration seems doable? Or will there be obvious issues?
Thanks in advance,
Best regards,
PS: The post describing the issue was posted in 2012. Maybe has it been fixed?
Thanks in advance,
Best regards,
