I'm trying to control the lights connected to Domoticz with the Logitech elite remote.
That way i can control them with the remote and also with the domoticz app. So far no success.
Some of the buttons can be programmed, I can also make a device Raspberry pi in the hub, but from there I get stuck.
Is there a way to accomplish this, or is it a no go. Google can't help me accept for using a ir to rf converter.
Thx in advance.
Alex
Controling the lights in Domoticz with the Logitech elite remote
TakeAway
- Domoticz version: 3.7722
Raspberry Pi 3 - Domoticz 3.7722 - Aeon Labs Z-Stick GEN5 - RFXcom version: Ext/1012- Logitech Harmony Elite - Homebridge - Fibaro FGMS-001-ZW5 - Fibaro FGDW-002-01 - KAKU stuff.
Venron
Re: Controling the lights in Domoticz with the Logitech elite remote
Hm you might be able to get this if you add a not phisically existing IR device to your Hamony Hub (like a Honewell air con).
But it will only work if the Hub reports this device to be turned on, don't know if its doing this for devices or only for activities.
If it does Domoticz could turn on the lights by an event which is triggered by the Harmoncy Hub ( device f.e. "Honewell air con "turned on)
TakeAway
Hi Venron,
I can give that a try, will report later!
Cornholio1234
- Domoticz version: V3.4964
Windows Server, Aeotec Z-Stick Gen5, V3.4964
TakeAway
No i didn't, will check that out too! Thx!
Seems to be what i am searching for!
- Arkie
I'm using the harmony elite, you can use it with the hue bridge, i bought and returned 2 hue bulbs after adding them to the hub first. So now i use those 2 dummy hue bulbs to activate a scene or some other domoticz stuff.
Synology DS412+
Philips Hue
Fibaro
Logitech Hamony elite
Foscam 9804 ip cam
RFXtrx433E USB 433.92MHz
ZXT 120 eu AC controller
Heatmiser NEO stat thermostats and Hub
Philips Hue
Fibaro
Foscam 9804 ip cam
