Mass storage boot for Raspberry Pi 3 only
Posted: Saturday 06 August 2016 19:20
by tommit01
using a new bootloader... currently beta
No SD card needed anymore.....
https://www.raspberrypi.org/blog/pi-3-b ... rage-boot/
Have a look at the blog pages for other boot modes.. Part 2 Ethernet
https://www.raspberrypi.org/blog/pi-3-b ... e-awesome/
Jepp...#
Note: this is still in beta testing and uses the “next” branch of the firmware. If you’re unsure about using the new boot modes, it’s probably best to wait until it is fully released.
Re: Mass storage boot for Raspberry Pi 3 only
Posted: Sunday 07 August 2016 14:23
by gizmocuz
I use BerryBoot to boot to an iSCSI drive on my synology nas, this way, it is also backuped
http://www.berryterminal.com/doku.php/berryboot
Posted: Tuesday 09 August 2016 23:10
by remb0
What about performance? I use always samsung class 10 cards and from the beginning of my domoticz adventures I never had any problems.. and this way it costs an usb port.
Posted: Wednesday 10 August 2016 4:20
by tommit01
@Gizmocuz But do you still need a SD Card?
@rembo I have no performance critical things.. if you use USB you should have about 30 - 40 MB/sec
Raspberry Pi3 has 4 USB Ports isn't this enough?
Advantage: I use a Sandisk Ultra Fit 16 GB 8 Euros each.... an this can be used everywhere, no SD, micro SD format issue between Raspberry 1,2 or 3...
Posted: Wednesday 10 August 2016 8:14
by gizmocuz
@tommit01
The raspberry has a 100mb network connection, that is fast enough to write data to the sqlite database ;)
There is a small boot delay because of the startup menu of berryboot, but thats it
Posted: Wednesday 10 August 2016 8:31
by Egregius
I used NFS for a while on several Pi's but returned to microSD.
Found it less stable, some services stopped from time to time. Webinterface available but ssh isn't, or reversed.
It's not that hard to move a lot to tempfs, that way you'll avoid already a lot writes.
Posted: Monday 03 October 2016 21:52
by mobisat
@tommit01
Did you simply follow this tut using the Domoticz image?
https://www.raspberrypi.org/documentati ... des/msd.md
Or was there more to it? My Pi 3 should arrive tomorrow
Posted: Tuesday 04 October 2016 5:57
by tommit01
@mobisat At this time I used a discussion thread in a forum.
but this How To Guide is much better because it is more condensed...
BR
TommIT
