I restored a database from my domoticz which is installed on a windows system into my Domoticz raspberry installation.
When I went to my camera's I saw that one of my camera's is not working on my raspberry domoticz. The same camera is working fine on my Domoticz windows installation.
The settings are exactly the same so I don't understand why it is not working on my raspberry installation.
Camera does not work on a domoticz raspberry
markk
Re: Camera does not work on a domoticz raspberry
I have 7 cameras and all were working fine when I had Domoticz running on windows. Since switching to a RPi 3 however, all but 2 of them no longer connect. I booted up the old windows PC tonight and they are all showing fine on that still. I have found the cameras to be the only problem I've encountered since switching over from windows to RPi but it is really frustrating. I loved this functionality. I hope someone can help me solve this.
UPDATE - I'm running the latest beta on my Pi3 but to test this further I downloaded a fresh install of Domoticz onto an SD card, inserted it into an old Pi2 and added the cameras individually and they all worked. Not sure where to start troubleshooting this
KingOfNuls
Try to put the credentials in the URL setting:
http://www.domoticz.com/forum/viewtopic ... 986#p96601
Regards.
Regards.
RPI B - domotiga connected to my visonic alarm
RPI 2 - domoticz connected to 1 wire temp sensors and teleinfo ("power smartmeter")
RPI 3 - domoticz master with mysensors and RFLink gateways
markk
Hi. Thanks for your reply. Yes, I put that in and the image was there so I input those details into the camera settings in Domoticz and it worked
I'm still confused as it worked with just snapshot.cgi previously and on the other Pi but, who cares, as long as I've got it working now. You've just made my weekend
