I'm trying to integrate my bticino system with domoticz.
I’ve achieved to control the blinds using integrated configuration (hardware bTicino, type Light/Switch, subtype Legrand MyHome) but i can control the lights only by scripts.
Using scripts i must wait 30" for switch a light from on to off...it's frustrating!
Can you help me to remove this delay?
Ps
why don't make dedicate switch like blinds?Or i miss this feature?
Integrate Bticino lights
trixwood
Re: Integrate Bticino lights
You can edit your switch and make it a blinds type (there are 4 different blind types) just go to switches select your switch and press the edit button.
30" is that 0.30 seconds or 30 seconds? cuz 0.30s is ok, everything above the second not.
Personally I tried a zwave bulb first, which switched on/off changed colour after 2-5 seconds, could not stand that. If I opened a door like in the hallway and entered the hallway, the light went on after I already left through the front door. Also it didn't change colour smoothly but abruptly.
Switches to philips hue and never looked back.
You could post your script here...
