Switch On/Off - Polycontrol Danalock Circle/Square
Posted: Tuesday 02 August 2016 8:01
by micksel
I have connected a Polycontrol Danalock Square Lock to my Domoticz and Everything works fine exakt, i seems that the lock reports the status enverted? so unlock in domotics is locked and locked in domotics is open,
I will try to change a paremeter on the lock tonight, Invert Lock Direction but don't feel right but will get back on this.
Re: Switch On/Off - Polycontrol Danalock Circle/Square
Posted: Tuesday 23 August 2016 15:56
by sickboyelsass
Hello Micksel,
I'm thinking of buying a Danalock as well and integrate it in Domoticz. Did you get your problem solved ?
Is everything working as expected?
Posted: Tuesday 23 August 2016 16:02
by micksel
Yes got it working ok but the lock doesen't update status IF you use key
Posted: Wednesday 24 August 2016 17:28
by elmortero
Hi Micksel,
How were you able to add it?
Mine is not seen. Did you move your domoticz next to the lock (as described in the manual?
Because that seems a bit complicated in my case, especially since z-wave has a much larger range that the described 1 meter in the Danalock manual.
Posted: Wednesday 24 August 2016 20:36
by micksel
yes, no problems there, I just set the look in correct mode, Think It was to hold the 2 button to the second beep, then took my phone, when to domo and the z-wave meny and added a secure "Product"
Posted: Sunday 08 January 2017 15:42
by smedberg
@micksel, did you find a solution to the inverted lock status?
Posted: Wednesday 25 January 2017 9:04
by micksel
@Smedberg I just answered your PM, but answer is yes
