External Temp/Baro with METAR script
ld57
Post by ld57 »
Hi!
I've just finished my 1st Domoticz script: it will give you external temperature and barometer by querying METAR (https://en.wikipedia.org/wiki/METAR) stations.
1- Make sure you have the "curl" package on your PI
2- Simply find your nearest METAR stations and edit the station variable below.
3- Idx is of course the index of a virtual sensor "Temp + Humidity + Baro".
script_time_metar.lua:
-- METAR time script
local idx = 10
local station = "LFJL"
command = "curl http://tgftp.nws.noaa.gov/data/observations/metar/stations/" .. station .. ".TXT"
local m = os.date('%M')
if (m % 30 == 5) then
        -- update at 5 and 35 minutes of every hour
        local handle = io.popen(command)
        local data = handle:read("*a")
        handle:close()
        if (data == '') then
                 print("Error metar data not fetched")
                 return
        data = string.gsub(data, "M", "-")
        local pres = tonumber(string.match(data, ' Q([0-9]+)'))
        local temp = tonumber(string.match(data, ' ([-0-9]+)/[-0-9]+ '))
        local dew = tonumber(string.match(data, ' [-0-9]+/([-0-9]+) '))
        local fore = 5
        -- very basic prediction
        if (pres < 1000) then
                fore = 4
        elseif (pres < 1020) then
                fore = 3
        elseif (pres < 1030) then
                fore = 2
                fore = 1
        -- print (data, pres, temp)
        local hum = 100*(math.exp((17.625*dew)/(243.04+dew))/math.exp((17.625*temp)/(243.04+temp)))
        commandArray[1] = {['UpdateDevice'] = idx .. '|0|' .. temp .. ';' .. hum .. ';0;' .. pres .. ';' .. fore}
It will run 2 times per hour since METAR data is not updated often.
I may improve that script with weather prediction soon.
Enjoy!
Domoticz + RPI3B+ + Zwave devices + RFLink
My blog: https://drolez.com/blog/
ld57
Re: External Temp/Baro with METAR script
Post by ld57 »
Hi!
I've updated the script so that the 'metar' package is no longer needed, only curl. I also added basic weather prediction and humidity calculation.
Enjoy!
pavelbor
Domoticz version: LastBeta
Post by pavelbor »
looks like script does not handle minus temperatures.
M04/M07 indicates the temperature is −4 °C (25 °F) and the dew point is −7 °C (19 °F). An M in front of the number indicates that the temperature/dew point is below zero Celsius.
local temp = tonumber(string.match(data, ' ([0-9]+)/[0-9]+ '))
METAR:
2017/01/03 12:20
EETN 031220Z 23005KT 180V260 9999 3600E -SHSN BKN009 FEW014CB BKN032 M04/M07 Q0999 RESHSN R08/490395 NOSIG
ld57
Post by ld57 »
Thanks! I've just updated the script above to fix this bug :)
pavelbor
Post by pavelbor »
Thanks for quick reply! Good job!
Would be nice to add wind information from METAR data into Domoticz WIND type dummy sensor.
12012MPS indicates the wind direction is from 120° (east-southeast) at a speed of 12 m/s (23 knots; 27 mph; 44 km/h). Speed measurements can be in knots (abbreviated KT) or meters per second (abbreviated MPS).
090V150 indicates the wind direction is varying from 90° true (east) to 150° true (south-southeast).
lost
Post by lost »
pavelbor wrote:Thanks for quick reply! Good job!
Some airports already reports their data through open weather... and wind data is taken into account.
