Dim Qubino ZMNHDD1 with I2/I3
Posted: Friday 29 July 2016 9:43
I've bought a number of Qubino ZMNHDD1 dimmers and I want to operate them with a 'double' pulse switch, which is actually created to operate blinds.
Pushing the up switch should dim up, pushing the down switch should dim down.
Question 1: my idea was that this could be realized using the different switches on the dimmer (I1/I2/I3), e.g. use I1 to dim up and I2 to dim down. Reading this forum, that apparently doesn't work, correct? The dim function is only available on I1?
Question 2: if the answer to Q1 is no, can I use one of the switches to set the light to a certain preset (e.g 75%)? In that case I'll use I1 to do basic control (on/off/dim up/dim down) and I2 to set to dim level 75%. Even better would be for I2 to toggle between 75% and off. Is that possible and how?
Thanks in advance for your thoughts!
