I've bought a number of Qubino ZMNHDD1 dimmers and I want to operate them with a 'double' pulse switch, which is actually created to operate blinds.
Pushing the up switch should dim up, pushing the down switch should dim down.
Question 1: my idea was that this could be realized using the different switches on the dimmer (I1/I2/I3), e.g. use I1 to dim up and I2 to dim down. Reading this forum, that apparently doesn't work, correct? The dim function is only available on I1?
Question 2: if the answer to Q1 is no, can I use one of the switches to set the light to a certain preset (e.g 75%)? In that case I'll use I1 to do basic control (on/off/dim up/dim down) and I2 to set to dim level 75%. Even better would be for I2 to toggle between 75% and off. Is that possible and how?
Thanks in advance for your thoughts!
Dim Qubino ZMNHDD1 with I2/I3 Topic is solved
mcwieger
- Domoticz version: 2020.1
I moved to HomeAssistant. It was fun while it lasted!
- bbqkees
- Domoticz version: 4.1x
Re: Dim Qubino ZMNHDD1 with I2/I3
Change 'Parameter no. 20 – Enable/Disable 3way switch' in the configuration. It enables specifically the mode you ask for in your question 1.
mcwieger
Thanks. I already checked with Qubino support and they provided the same answer. Will let you know the result after installing and configuring.
mcwieger
Works perfectly! Dimming up controlled by I1, Dimming down by I2. Switching on/off can be done by both buttons, always switching on to latest dim value.
