Page 1 of 3
Smarter Wifi iKettle 2 script for Domoticz
Posted: Friday 29 July 2016 8:10
by ben53252642
This is a python script for controlling the new smarter iKettle 2
Usage is simple, set the IP address of the iKettle2 and Domoticz server in the script and then use it like this:
python kettle.py control on40 (this command would boil the kettle to 40 degrees).
python kettle.py control on60
python kettle.py control on80
python kettle.py control on100
python kettle.py control on (this command would boil the kettle to 100 degrees).
python kettle.py control off
python kettle.py status monitor
python kettle.py status domoticzsync
kettle.py
import requests
import socket
import sys
import time
import json
import urllib
# Domoticz Settings
server = "USERNAME:[email protected]:80"
# iKettle 2 Settings
host = '192.168.0.85';
port = 2081;
# Kettle Control --------- Start
if sys.argv[1] == "control":
        if sys.argv[2] == "on40":
                message_to_send = "\x15\x28\x00\x7e"
        if sys.argv[2] == "on60":
                message_to_send = "\x15\x3C\x00\x7e"
        if sys.argv[2] == "on80":
                message_to_send = "\x15\x50\x00\x7e"
        if sys.argv[2] == "on100":
                message_to_send = "\x21\x7e"
	if sys.argv[2] == "on":
	if sys.argv[2] == "off":
		message_to_send = "\x16"
	try:
		s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
		s.connect((host, port))
		s.send(message_to_send)
		data = s.recv(10)
		s.close()
	except socket.error, msg:
		print 'Failed to create socket. Error code: ' + str(msg[0]) + ' , Error message : ' + msg[1]
		sys.exit();
	return_code = unicode(data)
	success=0
	message=""
	if return_code =="\x03\x00~":
		success=1
		message="Kettle has received the command."
	else:
		message="check kettle"
	print message
	quit()
	sys.exit()
# Kettle Control --------- End
# Kettle Status Monitor --------- Start
if sys.argv[1] == "status":
	while 1:
		from array import array
		incommingCommandSecond = ""
		incommingCommandFirst = ""
		try:
		except socket.error:
		    print 'Failed to create socket'
		    sys.exit()
		statusMessageType = {
			'0x0' : "Ready",
			'0x1' : "Boiling",
			'0x2' : "Keep warm",
			'0x3' : "Boiling finished??",
			'0x4' : "Cooling? not sure",
		locatedMessageType = {
			'0x9' : "On base",
			'0xa' : "On base",
			'0x8' : "On base",
			'0x7' : "Off base",
		s.connect((host , port))
		print 'Socket Connected to ' + host + ' on ip ' + host
#		while 1:
		reply = s.recv(4096)
		incommingCommandFirst = reply
		if incommingCommandFirst == incommingCommandSecond:
			pass
		else:
			incommingCommandSecond = reply
			a = array("B", reply)
			b = map(hex, a)
			deviceMessage = b[0]
			statusMessage = b[1]
			temperatureMessage = int(b[2], 0)
			locatedMessage = b[3]
			waterlevelMessage = int(b[4], 0)
			print
			if waterlevelMessage < 85:
				waterlevel = "Empty"
			if waterlevelMessage > 85 < 105:
				waterlevel = "Not enough water"
			if waterlevelMessage > 105 < 138:
       	                	waterlevel = "1 Cups"
			if waterlevelMessage > 140 < 160:
				waterlevel = "2 Cups"
			if waterlevelMessage > 160 < 180:
                       	 	waterlevel = "3 Cups"
			if waterlevelMessage > 180 < 200:
                        	waterlevel = "4 Cups"
                	if waterlevelMessage > 200 < 220:
                        	waterlevel = "5 Cups"
			if waterlevelMessage > 220 < 250:
				waterlevel = "6 Cups"
			if waterlevelMessage > 250:
                       		waterlevel = "Max full"
			print 'Status:', statusMessageType[statusMessage]
			if temperatureMessage is not 127:
				locatedMessage = "On base"
			if temperatureMessage is 127:
				locatedMessage = "Off base"
				temperatureMessage = "unavailable"
				waterlevel = "unavailable"
			print 'Located:', locatedMessage
			print 'Temperature:', temperatureMessage
			print 'Water level:', waterlevel
# Kettle Status Monitor --------- End
			# Kettle Domoticz Sync --------- Start
			if sys.argv[2] == "domoticzsync":
				# Get the Kettle Status in Domoticz, compare against current value and update if not match
				url = "http://" + str(server) + "/json.htm?type=command&param=getuservariable&idx=8"
				response = urllib.urlopen(url)
				data = json.loads(response.read())
				if data["result"][0]["Value"] != str(statusMessageType[statusMessage]):
					requests.get("http://" + str(server) + "/json.htm?type=command&param=updateuservariable&vname=Kettle Status&vtype=2&vvalue=" + str(statusMessageType[statusMessage]))
				# Get the Kettle Location in Domoticz, compare against current value and update if not match
				url = "http://" + str(server) + "/json.htm?type=command&param=getuservariable&idx=9"
				if data["result"][0]["Value"] != str(locatedMessage):
					requests.get("http://" + str(server) + "/json.htm?type=command&param=updateuservariable&vname=Kettle Location&vtype=2&vvalue=" + str(locatedMessage))
				# Get the Kettle Temperature in Domoticz, compare against current value and update if not match
				url = "http://" + str(server) + "/json.htm?type=command&param=getuservariable&idx=10"
				if data["result"][0]["Value"] != str(temperatureMessage):
					requests.get("http://" + str(server) + "/json.htm?type=command&param=updateuservariable&vname=Kettle Temperature&vtype=2&vvalue=" + str(temperatureMessage))
				# Get the Kettle Water Level in Domoticz, compare against current value and update if not match
				url = "http://" + str(server) + "/json.htm?type=command&param=getuservariable&idx=11"
				if data["result"][0]["Value"] != str(waterlevel):
					requests.get("http://" + str(server) + "/json.htm?type=command&param=updateuservariable&vname=Kettle Water Level&vtype=2&vvalue=" + str(waterlevel))
				print
				print 'Domoticz Sync Mode Active'
			# Kettle Domoticz Sync --------- End
if sys.argv[1] == "help":
	print
	print 'Usage:'
	print 'python kettle.py control on40 (this command would boil the kettle to 40 degrees)'
	print 'python kettle.py control on60'
	print 'python kettle.py control on80'
	print 'python kettle.py control on100'
	print 'python kettle.py control on (this command would boil the kettle to 100 degrees)'
	print 'python kettle.py control off'
	print 'python kettle.py status monitor'
	print 'python kettle.py status domoticzsync'
	print
If you use python kettle.py status domoticzsync, you can setup 4 variables in Domoticz and the script will update them if the device status changes. Be sure to set the IDX value for each device in the kettle.py so it knows which variable to update in Domoticz, these are in the "Kettle Domoticz Sync" section of the script.
Screen Shot 2016-07-31 at 6.50.54 AM.png (79.12 KiB) Viewed 5525 times
All the variable types in Domoticz for the kettle should be set to: String
The water level (number of cups) was measured by putting one cup of water after another into the kettle and recording the values to come up with an approximate number of cups that the number represents.
Here is a one line script for running kettle.py in a screen session (useful for having it run 24/7 in the background) and on startup checking the status and updating Domoticz. I put this into a file called startup.sh in the same directory as kettle.py then gave it executable permissions using chmod 755 startup.sh then finally I told the system to put it into startup using: update-rc.d kettlebridge defaults
/usr/bin/screen -S KettleMonitor -d -m python /root/smarter/kettle.py status domoticzsync
Then I wanted the startup.sh script to automatically run each time the system boots and run in the background so I created a script:
nano /etc/init.d/kettlebridge
inside I put this code (making sure to set the location to the startup.sh in the script)
#!/bin/sh
### BEGIN INIT INFO
# Provides: kettlebridge
# Required-Start: $network
# Required-Stop: $network
# Default-Start: 2 3 5
# Default-Stop:
# Description:
### END INIT INFO
case "$1" in
'start')
        /root/smarter/kettle/startup.sh
'stop')
        echo "Usage: $0 { start | stop }"
esac
exit 0
Then I granted kettlebridge executable permissions using chmod 755 kettlebridge
I also wanted to automatically restart kettlebridge if it crashed for some reason so I put this code into Monit, read here if you don't know what Monit is:
https://www.domoticz.com/wiki/Monitoring_domoticz
The code for Monit which I put into the file /etc/monit/monitrc is:
# Monitor Kettle Bridge
check process KettleBridge with match KettleBridge
  start program = "/etc/init.d/kettlebridge start"
  if cpu usage > 70% for 3 cycles then restart
  if memory usage > 50% for 3 cycles then restart
Monit has a nice web interface, I have many bridges and scripts being monitored by it every 30 seconds.
Screen Shot 2016-07-31 at 10.19.27 AM.png (42.89 KiB) Viewed 5482 times
Here is an example Lua script for doing something when a variable status changes (in this case Ready vs Boiling), note that the script MUST be placed in the Domoticz/scripts/lua directory and that the file name MUST start with: script_variable
In this case the full file name I'm using is: script_variable_kettle.lua
You cannot simply place this script in the "Events" web interface, it must go in a file in the directory mentioned above.
-- Announce if the kettle is boiling
if (uservariablechanged['Kettle Status'] == 'Boiling') then
   os.execute ('sh /root/domoticz/speak.sh "speaker3 Boiling initiated."')
-- Turn off the kettle when it's finished boiling and make verbal announcement
if (uservariablechanged['Kettle Status'] == 'Ready') then
   commandArray['Kettle']='Off'
   os.execute ('sh /root/domoticz/speak.sh "speaker3 The kettle has finished boiling."')
Here is a Lua script for controlling the kettle with temperature options, in this case I have a virtual selector device in Domoticz called "Kettle" and when I select a temperature option this script does the action to call Python kettle.py and control the kettle.
script_device_kettle.lua
-- Turn on the kettle (boil)
if (devicechanged['Kettle'] == '40°') then
    os.execute ('python /root/smarter/kettle/kettle.py control on40')
if (devicechanged['Kettle'] == '60°') then
    os.execute ('python /root/smarter/kettle/kettle.py control on60')
if (devicechanged['Kettle'] == '80°') then
    os.execute ('python /root/smarter/kettle/kettle.py control on80')
if (devicechanged['Kettle'] == '100°') then
    os.execute ('python /root/smarter/kettle/kettle.py control on100')
-- Manually turn off the kettle (if you use the switch in Domoticz and the kettle is boiling)
if (devicechanged['Kettle'] == 'Off' and uservariables["Kettle Status"] == 'Boiling') then
    os.execute ('python /root/smarter/kettle/kettle.py control off')
Each level name in the Domoticz selector switch is like so with the temperature option (40, 60, 80 or 100): 40°
Re: Smarter iKettle 2 script for Domoticz
Posted: Friday 29 July 2016 9:10
by Derik
great...
I do not have a thing like this..
Only the question for me is, how connect this Ikettle with domoticz ?
Posted: Friday 29 July 2016 9:51
by trixwood
No domoticz monitor but
Update: https://github.com/Tristan79/iBrew
Full console, command line also for smarter coffee.
Fun reading also explains some of the api (search github for wrappers):
https://www.pentestpartners.com/blog/sm ... onfigured/
https://www.pentestpartners.com/blog/ha ... ne-part-1/
Posted: Friday 29 July 2016 13:31
by ben53252642
Derik, you just use the mobile app to get the kettle on your wifi network, then you can use the above script to turn it on / off from Domoticz.
I also ordered the Smarter coffee machine at the same time as the kettle so I'll be posting a script for controlling that shortly. The kettle and the coffee machine use a very similar control mechanism. :)
Posted: Friday 29 July 2016 21:08
by ben53252642
It's also possible to control the kettle with a simple bash script for those not wanting to use Python
Usage (change the directory as needed):
/root/smarter/kettle.sh "on"
/root/smarter/kettle.sh "off"
#!/bin/bash
if [[ $1 == 'on' ]]; then
echo -e '\x21' | nc 192.168.0.85 2081
fi
if [[ $1 == 'off' ]]; then
echo -e '\x16' | nc 192.168.0.85 2081
fi
Posted: Friday 29 July 2016 21:11
by trixwood
Posted: Friday 29 July 2016 21:14
by ben53252642
Trixwood are you able to work out how one would set the temperature?
I've tried many different methods such as:
echo -e '\x21\x32' | nc 192.168.0.85 2081
The x32 translates to 50, if anyone is able to work out temperature it would be hugely appreciated.
Also I've not been successful in getting any detailed responses from the kettle, I can send commands but haven't worked out how to get the responses.
I've been working off exactly the page you linked.
Posted: Friday 29 July 2016 21:26
by trixwood
No do not have an ikettle, these guys have one
viewtopic.php?t=9861
Posted: Friday 29 July 2016 21:27
by ben53252642
That's the iKettle 1 which uses a different protocol unfortunately (I created a new thread for the iKettle 2).
I'll keep working on it and post once I have it figured out.
Cheers
Posted: Friday 29 July 2016 21:39
by trixwood
Check out this link:
https://github.com/Jamstah/libsmarteram ... umentation
Far better protocol description, Seems you have to end your messages with '0x7e'.
Posted: Friday 29 July 2016 21:42
by ben53252642
Yep also been looking at that page, interesting the on command mentioned
"0x15 Turn on (iKettle 2.0)."
Doesn't work for my machine, the on command for me is 0x21.
Just been going through working out what does and doesn't work putting a script together.
Posted: Friday 29 July 2016 21:49
by trixwood
Typos/different versions, more likely two different command options :-)
Try to:
echo -e '\x21\x32\x7e' | nc 192.168.0.85 2081
or
echo -e '\x15\x50\x7e' | nc 192.168.0.85 2081
You are not ending the messages
Posted: Friday 29 July 2016 22:02
by trixwood
And what is the output of do you get a status message back?
echo -e '\x14\x7e' | nc 192.168.0.85 2081
Posted: Friday 29 July 2016 22:05
by ben53252642
The top one boils the kettle to 100c ignoring the temperature
this one doesn't do anything
no messages come back using the bash method, if I use python I'm getting either
i~
or
If I connect to the unit via telnet it just sends this every second or so:
I mean not that I really need to be getting messages from the kettle... it's a kettle, boiling is sufficient functionality for me but it would just be nice to see the water level and be able to boil a lower temperature for making certain drinks.
Posted: Friday 29 July 2016 22:15
by trixwood
Looking at homey plugin for ikettle 2 i notice that they are sending a zero with it:
var turnOn = new Buffer([21, temperature, 0, 126]);
https://github.com/athombv/am.smarter/b ... ttle2.0.js
So have you tried?
echo -e '\x21\x32\0x00\x7e' | nc 192.168.0.85 2081
and are you sure it not x15 instead of x21?
The garbage output is because you have to decode the bytes.
try passing it to 'od -t x1'
echo -e '\x14\x7e' | nc 192.168.0.85 2081 | od -t x1
now you can read it as described in the protocol (for test purposes)
Posted: Friday 29 July 2016 22:31
by ben53252642
This is interesting
root@Domoticz:~/smarter# python kettle.py "status" | od -t x1
0000000 03 00 7e 0a
0000004
im sending \x100\0x00\x7e which should be for status
the 03 is for command acknowledged :)
Posted: Friday 29 July 2016 22:44
by trixwood
it seems (from the same homey plugin code)
that to keep your kettle warm you can use
enableKeepWarm(temperature, minutes) {
 new Buffer([21, temperature, minutes, 126])
that means the added 0 in the previous post is the time it keeps the kettle on temperature after it boils (i think that it).
Anyway good luck!
Posted: Friday 29 July 2016 22:51
by trixwood
btw monday/tuesday I can play with the real thing! So if you finish before that would be nice! :mrgreen:
Posted: Friday 29 July 2016 22:52
by ben53252642
lol, good choice, the kettle is very good quality. :D
Posted: Friday 29 July 2016 23:13
by trixwood
119 euro for europe verions
https://www.rovara.nl/smarter-ikettle-2 ... 0wodkF8E-g
108 euro for uk version
http://www.zavvi.nl/cadeau-huis-kantoor ... aign=Zanox
Still fragging expensive.
