Milight Dual White bulbs not pairing
Monki77
Post by Monki77 »
Hi all..
I received an RGB and a White Milight/Easybulb bulb today and tried to pair them both, with 50/50 results.
The RGB bulb has paired absolutely fine using the instructions given here -http://www.nemcon.nl/blog2/faq
The white bulb will not work though, i just cannot get it to respond/pair with my RFLink. I've even moved my RFLink to within a few meters just to make sure its not the range.
I'm using the standard command "10;MiLightv1;F746;01;34BC;PAIR;" as instructed. (I paired my RGB with 10;MiLightv1;F001;01;34BC;PAIR; so the ID is different)
Does the white bulb need a different string to pair? DOes "34BC" need changing to something else? I cannot find any info on google :(
Any help would be great please!
Thanks.
Monki77
Re: Milight Dual White bulbs not pairing
Post by Monki77 »
After reading into it more, "34BC" is the colour it sends to the bulb. So i thought maybe the White bulb is failing when its receiving a colour signal when pairing...
So, i set my working RGB bulb to white light and checked the domoticz log.. It shows the command sent as -
10;MiLightv1;F001;01;0000;ON;
I then tried sending 10;MiLightv1;F003;01;0000;PAIR; as the pairing command to my white bulb making sure the colour was 0000 (white).
It still won't pair :( I even saw a mention of MiLightV2 on domoticz github in the riflink code and thought i'd tried that. Still nothing..
I have no idea whats going on =/
Are these Dual White lights just not compatible?
Stuntteam
Post by Stuntteam »
Thats normal.. only the RGBW bulbs and remotes were supported with R42.
In R43 also the CW/WW and RGB bulbs and remotes are supported.
Monki77
Post by Monki77 »
Ah, at least I know it's not me then haha.
Sent from my SM-G930F using Tapatalk
ledfreak3d
Domoticz version: 3.8025
Post by ledfreak3d »
same problem here rgbww and rgbw works fine
but cant pair cw ww bulb
it does not respond at all
to below
10;MiLightv1;5A8296;02;0000;PAIR;
10;MiLightv1;5A8294;01;0000;PAIR;
domotics v3 8025 with rflink r46
anybody any idea
Unleashe the magic smoke ;)
ledfreak3d
according to the rflink site cw/ww should be supported
Stuntteam
Post by Stuntteam »
WHat is the milight FUT number?
ledfreak3d
where can i find those numbers ?
there are no model numbers on the light only milight cw/ww
ledfreak3d
sadly i dont have a white remote else i would have made you a data capture
anybody have a milight cw/ww buld and a white remote that can capture some data on rflink ?
ledfreak3d
its the FUT017 bulb
JoshDinsdale
Post by JoshDinsdale »
Hi Guys
I'm now running version 47 of the Milight firmware but am still unable to get my FUT035 LED strip controller to pair, I am using the 'A' set of instructions from the Milight FAQ on the Nodo site.
I can get it to pair and unpair to a milight remote just fine and I also have an older model Milight strip controller that works perfectly with my RFLink.
Any advice?
anton83
Post by anton83 »
Hi, I have the same problem .. I can not control with domoticz FUT019. I tried everything. Other drivers strips work without problems. Please help ..
