I have install the Domoticz of a rasbian distribution and a Raspberry 3.
I can not acces from my intranet with a navigator .... i think its ok ... but its not work ...
Copie from my terminal :
pi@raspberrypi:~/domoticz $ sudo service domoticz.sh start
pi@raspberrypi:~/domoticz $ sudo service domoticz.sh status
● domoticz.service - LSB: Home Automation System
Loaded: loaded (/etc/init.d/domoticz.sh)
Active: active (exited) since lun. 2016-07-18 12:06:03 UTC; 32min ago
Process: 559 ExecStart=/etc/init.d/domoticz.sh start (code=exited, status=0/SUCCESS)
juil. 18 12:06:03 raspberrypi systemd[1]: Starting LSB: Home Auto...
juil. 18 12:06:03 raspberrypi systemd[1]: Started LSB: Home Autom...
juil. 18 12:38:15 raspberrypi systemd[1]: Started LSB: Home Autom...
Hint: Some lines were ellipsized, use -l to show in full.
Can You help me
thank you
pascal
Not acces from navigator
- gizmocuz
Re: Not acces from navigator
First i would suggest to use the Domoticz SD card image (see the wiki)
Then when you are logged in as the 'pi' user issue:
ifconfig
you should see the IP address of the pi
Next, launch the Chrome browser, and navigate to this ip address on port 8080
http://<IPADDRESS>:8080
ifconfig
Users browsing this forum: eddieb and 1 guest
