razberry and TKB TZ68
sirray
Post by sirray »
My TZ68 and Domoticz on a raspberry pi with a Razberry z-wave controller almost daily loose their connection to each other. I tried healing but this does not fix this. After a reboot of the raspberry pi they can see each other again. First I thought the distance was to far, so I moved the raspberry closer to the device (3 meters away now), however this didn't fix the problem. What can I do to resolve the problem of the TZ68 not being available anymore in Domoticz?
sirray
Re: razberry and TKB TZ68
Post by sirray »
Unfortunally the problem still exists with the new version of Domoticz :-(
Does nobody know how to fix this?
sirray
Post by sirray »
I tried the following viewtopic.php?f=24&t=11179&p=100006&hil ... te#p100006 this also didn't work. Still searching :(
edwin72
Post by edwin72 »
The problem seems still not to be solved. I wonder if the modules are instable or Domoticz. Someone, who can explain why this message: Error: OpenZWave: Node not found occurs with these devices and why domoticz isn't able to work properly when such errors occur in the system?
WillemK
Post by WillemK »
I wonder if this problem is controller related, I now use the TZ68 on with an UZB stick and other software and I am experiencing also problems, however not daily. Sometimes the TZ68 works okay for several weeks, but then the first problem is that the status is not returned and after a while (days/week) it stops responding. I am thinking of replacing this module with another type/brand.
tequila
Post by tequila »
TKB TZ68 working just fine on my razberry and rpi2. I have 5 of these and I have never had a single issue. Have you tried to exclude/include after moving the controller closer?
WillemK
Post by WillemK »
Sorry that I did not respond to this earlier, it finally appeared a faulty TZ68. I got a replacement a few months ago and no problems since then.
