Domoticz & MyHome OpenWebNet
emme
Domoticz version: latest
Post by emme »
a friend of mine has a MyHome/OpenWebNet domotic server installed to control blinds and lights and he wishes to use Domoticz for scenes, notification and interaction with some other zWave devices and sensors
I installed Domoticz on a FreeNAS Jail... It wasn't easy and I still unable to connect the server on its IPv4 address (not binded) but only on its IPv6 local address (fe80::) :(
after getting connected to the home screen, I added the MyHome hardware, IP address and port (20000), added the Domoticz IPv4 IP on legrand server as a trusted IP...
all seems to works fine... BUT....
I've seen the blids came automatically (they're on BUS 1)... and I was able to configure all them... but there is no way to configure lights (on BUS 2), not automatically, nor manually by adding a switch (the only availble OpenWebNet is for blinds and not for lights/other bus than 1)
Is there a way to configure bus 2 for Legrand server?
thanks
ciao
M
"We always done this way"
