Qubino Weather Station ZMNHZD1
Posted: Monday 11 July 2016 8:50
Hi Folks,
I bought myself a Qubino ZMNHZD1 Weather station. https://www.momotica.nl/Domotica/zwave/ ... -Wave-Plus
This weatherstation sends its 433 mhz signals to a z-wave stick.
I am recieving the 433 mhz perfectly with my rfxcom and the station is well included in z-wave. but I don't get devices in z-wave.
At startup I get this for node 44 which is the weather station.
Anyone any idea?
2016-07-11 08:47:32.206 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Direction, Instance: 7
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Unhandled Label: Direction, Unit:
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Velocity, Instance: 6
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 5
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 6
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Rain Rate, Instance: 12
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Unhandled Label: Rain Rate, Unit: mm/h
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 9
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 2
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 3
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 4
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 5
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 6
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 7
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 8
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 9
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 10
2016-07-11 08:47:32.225 RFXCOM: Using serial port: /dev/ttyUSB0
Thnx in advance for any help
Jan
Anyone any idea?
Jan
