Qubino Weather Station ZMNHZD1
JuanUil
- Domoticz version: 4.11083
Hi Folks,
I bought myself a Qubino ZMNHZD1 Weather station. https://www.momotica.nl/Domotica/zwave/ ... -Wave-Plus
This weatherstation sends its 433 mhz signals to a z-wave stick.
I am recieving the 433 mhz perfectly with my rfxcom and the station is well included in z-wave. but I don't get devices in z-wave.
At startup I get this for node 44 which is the weather station.
Anyone any idea?
2016-07-11 08:47:32.206 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR BINARY, Label: Sensor, Instance: 0
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 1
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Direction, Instance: 7
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Unhandled Label: Direction, Unit:
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Velocity, Instance: 6
2016-07-11 08:47:32.207 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 5
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 6
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Rain Rate, Instance: 12
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Unhandled Label: Rain Rate, Unit: mm/h
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Relative Humidity, Instance: 5
2016-07-11 08:47:32.208 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: SENSOR MULTILEVEL, Label: Temperature, Instance: 9
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 1
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 2
2016-07-11 08:47:32.210 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 3
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 4
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 5
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 6
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 7
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 8
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 9
2016-07-11 08:47:32.211 OpenZWave: Value_Added: Node: 44 (0x2c), CommandClass: BATTERY, Label: Battery Level, Instance: 10
2016-07-11 08:47:32.225 RFXCOM: Using serial port: /dev/ttyUSB0
Thnx in advance for any help
Jan
Anyone any idea?
Jan
JuanUil
Re: Qubino Weather Station ZMNHZD1
anyone any idea?
piotr
What is the point in "converting" from 433mhz to z-wave ? If rfxcom knows the Qubino protocol you can skip the z-wave part.
JuanUil
because I want to skip my rfxcom
tdv94lnn
- Domoticz version: 3.5691
Have you been able to get it to work? I also have some problems with this.
see viewtopic.php?f=12&t=12813&p=91862&hilit=ZMNHZDx#p91862
JuanUil
Hi There,
I still get all the values by rfxcom but nothing from z-wave.
tdv94lnn
I get som sensor values after updating the openZWave configuration files, but not all...
- Varazir
I hade problem with my Qubino(not weather station), I removed and added the node for it and got my to work.
tdv94lnn
@Varazir, could you please post you configuration deta regarding this node. What is defined in zwcfg?????.xml file for this node.
- Varazir
tdv94lnn wrote:@Varazir, could you please post you configuration deta regarding this node. What is defined in zwcfg?????.xml file for this node.
I have a ZMNHOD1 not ZMNHZD1. As I said I just re added the device to zwave it started to work.
JuanUil
Hi there,
Has anyone made any progress on recieving the data via z-wave on this weatherstation?
Grtz. Jan
Grtz. Jan
JuanUil
No one to report any progress?
CrazyFin
I registered to this forum as a non-Domoticz user (have tested it a while ago though and use it sometimes for device testing as well).
I am trying to the Qubino Weather Station ZMNHZD1 on Indigo Domotics (with Aeon Labs Z-Wave USB stick, not the new Gen5 stick though) and I experience the same problems there, i.e the Z-Wave dongle for the weather station does not seem to transmit out sensor data for the temp/humidity sensor channel 2, rain sensor and wind sensor.
I can see on the dongle that it does indeed receive data from the sensors but somehow it does not transmit it further on to the Z-Wave controller.
I am not sure if this is a firmware bug or that the dongle transmits its Z-Wave data in wrong way or that the device specifications/command classes are not following the documentation. (See my thread in the Indigo forum at http://forums.indigodomo.com/viewtopic.php?f=58&t=16262).
I tested also with Z-Way Server on Windows together with the Z-Wave.ME UZB stick and same problems there.
Looking in Vera forums it seems that this weather station is not compatible with Vera either.
My dongle seems to have firmware 1.02.
I have emailed Qubino support but no repsonse yet.
CrazyFin
Alright, I compiled OpenZWave library 1.4.2268 and used OpenZWave Control Panel on my Ubuntu 14.04 LTS test machine.
No issue to include/add the device to my controller ZWave.ME UZB1 stick (firmware 5.06).
After a few minutes I started to get updates from all 10 sensors/endpoints so the ZMNHZDx device is working as it should.
JorisVandoren
I've bought the same weatherstation and experience the same problems like JuanUil reported.
I have this station now already a couple of months but can't get it working in my z-wave network.
Here I read Jan was able to get it communicating via RFXCOM. I'd like to know what protocols need
to be enabled to start the communication between the sensors and RFXCOM.
Currently I have only AC and Oregon OWL enabled in the RFXtrx433 device.
Greetings,
Joris
Greetings,
Joris
JuanUil
Hi I have,
Blind T1/T2/T3/T4
Oregon scientific
AC
ARC
X10
enabled, succes!!
Jan
Blind T1/T2/T3/T4
Oregon scientific
AC
ARC
X10
enabled, succes!!
Jan
tdv94lnn
Is fully supported in OpenHAB2 and works really well. To bad that Domoticz doesnt support it yet
JuanUil
An old post but since I am completely reconfiguring my Domoticz I was wondering if this weatherstation is now supported with Domoticz.
Anyone succeeded?
Jan
Anyone succeeded?
Jan
