Problem with my devices
dreuf
Post by dreuf »
My domoticz got buggy, after several reboots and reinstallment of the update my Node screen now look like this:
All id and type are 0x0000 and nothing is working.
I have had this one time before and then I needed to reinclude all my devices.
I dont want to do that again (remove lamps and so on to be able to access the nodes...)
Are there any way to fix this the software way?
elmortero
Domoticz version: 3.9639
Re: Problem with my devices
Post by elmortero »
I don't see a zwave controller in that list.
Maybe it is not properly detected/installed.
Cornholio1234
Domoticz version: V3.4964
Post by Cornholio1234 »
Did you try do delete the zwave config file to force openzwave to refresh all settings?
Windows Server, Aeotec Z-Stick Gen5, V3.4964
dreuf
Post by dreuf »
Controller is on the next page, sorry about that. Its an UZB1.
Havent tried to delete the zwave config file, where is it located?
dreuf
Post by dreuf »
Think I found the config file, was named zwcfg_0xf992....xml, correct?
dreuf
Post by dreuf »
I stoppet domoticz, removed the cfgfile and restarted domoticz. All is now working, thnx so mutch!
