Major issues with Fibaro Motion Sensor
dhanjel
Domoticz version: 3.5146
Post by dhanjel »
Is anyone currently working with the major issues there seems to be with Fibaro motions sensor?
Or is it just me that has problems with the motion devices?
I have 5 in total, only one have temperatures reporting, and one of the other has light level but no temperature.
Three have 2 - 3 random devices but mostly no temperatures.
And in addition to this, they only seems to work a couple of days and then no activity whatsoever.
I have a lot of scenes based on motion so this is a real set back for me in an otherwise excellent system (dzVents just makes scripting magically fun)
Working unit (right now):
Non-working unit (does not help to exclude/include again):
Kerneldomoticz
Domoticz version: 3.5248
Re: Major issues with Fibaro Motion Sensor
Post by Kerneldomoticz »
can you also describe yoru hardware ? it might help the guys on the forum.
did you try to exclude - include all motion sensors with deleting the devices in the device list ?
flo
dhanjel
Post by dhanjel »
z-wave.me stick (https://www.z-wave.me/index.php?id=28)
domoticz 3.5290
running on an intel nuc with ubuntu
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
I have 3 Fibaro's and no problems whatsoever.
Allready running for a year now.
dhanjel
Post by dhanjel »
Weird. I have spend countless hours on trying to fix this.
Egregius
Domoticz version: v2024.7
Post by Egregius »
Same here, have 5 of them for motion and they work perfect.
I do disable the temp and lux instantly after inclusion because I don't need that.
dhanjel
Post by dhanjel »
And when including, you simply select "include node", press the button on the back of the motion sensor three times and everything is done?
Egregius
Post by Egregius »
Yes.
Could take some time for the termometer and lightmeter to appear. They are only created when they send an update. Guess that's after 1 degree change by default.
dhanjel
Post by dhanjel »
Will try to put one outside for a bit and see if I get anything :)
Egregius
Post by Egregius »
Or wake it up and change the settings to 0.1 degree and 1 lux difference.
dhanjel
Post by dhanjel »
had it outside for a couple of hours then inside for a couple more, no new devices at all
jvdz
Domoticz version: 4.107
Post by jvdz »
You do have the option: Accept new Hardware Devices selecting in the Setup/Settings menu?
Jos
dhanjel
Post by dhanjel »
"unfortunately", yes
3rik
Post by 3rik »
I have the same stick and same setup as you. Got the same problem with fibaro motion sensors. No light or temp from them. So my guess it's the uzb1 stick. Are you running the latest firmware on the stick?
dhanjel
Post by dhanjel »
No idea, have been trying to find anything about firmware upgrade on their homepage without result.
But it sounds indeed like the problem resides with the stick.
Sent from my Nexus 6P using Tapatalk
Kerneldomoticz
Personnaly i was using the Z.wave me GPIO card before and i had so many issues ... and stability problem. now since i moved to Aeotec Zstick gen5 no more problem of stability. i have like 6-7 fibaro motion sensors and everything is fine.
3rik
Post by 3rik »
dhanjel wrote:No idea, have been trying to find anything about firmware upgrade on their homepage without result.
I'm using the latest firmware, so still buggy.
To upgrade the firmware you need to install the Z-Way server software. In there you will find a option to firmware upgrade.
dhanjel
Post by dhanjel »
So, the solution seems to be to throw away this usesless device then and buy the Aeontec stick instead?
DanM
Post by DanM »
Are these new by any chance? I have had two fibaro for a year and they work fine. I added two more this week and they don't work properly at all. Could be new fibaro firmware?
DanM
Post by DanM »
I'm using the aoetec gen 5 stick too.. so don't rush out to upgrade your stick if they are new.
