do i need to store scripts in the script folder ?
deejc
Domoticz version: 3.5641
Post by deejc »
i use domoticz in docker so i only have one folder mapped and its not the scripts folder, its a folder called config where the DB is stored, if create a scripts folder under the config folder and point the scripts like
script:///config/scripts/scripts.lua etc will it work correctly?
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
dannybloe
Re: do i need to store scripts in the script folder ?
Post by dannybloe »
You can easily add more folder mappings using Docker and have the script folder sit in the original location (domoticz/scripts/lua).
I used to do this:
docker run -d -p 8080:8080 --restart=on-failure:10 --name=domoticz -v /volume1/docker/domoticz/data:/db -v /volume1/docker/domoticz/lua:/src/domoticz/scripts/lua -v /volume1/docker/domoticz/log:/log -v /etc/localtime:/etc/localtime:ro --device=/dev/ttyUSB0:/dev/ttyAMA0 domoticz
deejc
Post by deejc »
I'll try it, thanks
