ping with lua and switch
tiga
Post by tiga »
hello, i am running a little ping test.
i have a virtual switch made to see the status of my tablet (testping).
this is the script i use
ping_success=os.execute('ping -c1 192.168.0.113') --tablet
if ping_success then
print("tablet online")
commandArray['testping']='On'
print("tablet offline")
commandArray['testping']='Off'
i do this in lua becouse the standard "system alive checker" does give valse info.
the script works fine but....i want my virtual switch to change only if the ping result changes
in other words the "last seen" time not updated every 30 or what seconds....
can anyone help me?
hmmm not working fine afterall.when i am offline i get:
Error: EventSystem: Warning!, lua script test ping has been running for more than 10 seconds
HELP :?
jvdz
Domoticz version: 4.107
Re: ping with lua and switch
Post by jvdz »
Have a look here before trying reinventing this : http://domoticz.com/wiki/Presence_detection :)
Jos
Derik
Post by Derik »
maomanna
Post by maomanna »
I don't understand the two answers.
The topicstarter ask for a ping script in lua, not in bash or python.
By using lua, you can adjust the sript easily in the webgui.
Otherwise you always have to do it by ssh
jvdz
Post by jvdz »
maomanna wrote:I don't understand the two answers.
True, but I would never put this function in the Event queue as it is single threaded and could make the eventsystem respond slow to other events during the processing of this function.
One could obvious still do the check in LUA but I would then schedule it as a crontab job.
Jos
dannybloe
Post by dannybloe »
I'd use dzVents for this. You can use the system-alive checker plugin and use a persistent variable in your script that increases everytime a time-out occurs (the checker triggers a switch which will trigger you script). You can then threshold it and only send a notification if you have a number of consecutive time-outs in a row. Works like a charm.
Something like this:
	active = true,
		'checkerSwitch', -- name of the switch that is triggered by the system-alive checker plugin
	data = {
		timeOuts = { initial = 0 }
	execute = function(domoticz, checkerSwitch)
		if (checkerSwitch.state == 'On') then
			domoticz.data.timeOuts = domoticz.data.timeOuts + 1
			domoticz.data.timeOuts = 0 -- reset
		if (domoticz.data.timeOuts > 5) then
			domoticz.notify('Oh my, the device is not responding anymore', domoticz.PRIORITY_HIGH)
dannybloe
Post by dannybloe »
I updated dzVents to 1.1.1 and it now contains a generic script example how to notify when a system-alive checker device is not responding anymore while preventing false negatives.
tiga
Post by tiga »
ok thanks i will try these out
sploutchi
Post by sploutchi »
Hi tiga,
I wrote an article on this subject : http://debrouilhome.fr/2015/07/domoticz ... n-lua.html
Enjoy :)
