Help needed -- lua script on Synology
steef84
Domoticz version: DS213+
Post by steef84 »
running Domoticz on my Synology for quite some time now. I'm using Jumbotroll his compiled package.
I wanted to try a lua script found here https://gathering.tweakers.net/forum/li ... 9#47264699, but i can't manage to get it working.
I recreated this with my own switches etc, and enabled a variable integer with value 0 named "Schemer_licht_aan". I also have the switches 'IemandThuis', 'State - IsDonker' and 'Vakantietimer' available. They are on/off switches..
local presence_switch = 'IemandThuis'
local isdark_switch = 'State - IsDonker'
local Vakantie_timer = 'Vakantietimer'
vSchemer_licht_aan = tonumber(uservariables['Schemer_licht_aan'])
function sleep(n)
  os.execute("sleep " .. tonumber(n))
if devicechanged[isdark_switch] then
    if (otherdevices[isdark_switch] == 'Off' and otherdevices['Zon op-onder'] == 'Off' and vSchemer_licht_aan >= 1) then
        commandArray['Group:Huiskamer']='Off'
        commandArray['Group:Huiskamer']='Off' AFTER 15
        commandArray['Vakantietimer']= 'Off'
        commandArray['Variable:Schemer_licht_aan'] = tostring(0)
        print('<font color="blue">LICHT - Het is licht geworden - Alle lampen uit!!</font>')
    elseif (otherdevices[presence_switch] == 'On' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 0) then
         commandArray['Vakantietimer']= 'On'
        commandArray['Group:Huiskamer']='On'
        commandArray['Group:Huiskamer']='On AFTER 10'
        commandArray['Variable:Schemer_licht_aan'] = tostring(1)
        print('<font color="blue">THUIS - Het is donker en er is iemand Thuis - Lichten gaan aan!!</font>')
    elseif (otherdevices[presence_switch] == 'Off' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 0) then
         commandArray['Scene:Sfeertje']= 'On'
        commandArray['Scene:Sfeertje']= 'On' AFTER 10
        commandArray['TV kijken']='On'
        commandArray['Variable:Schemer_licht_aan'] = tostring(2)
        print('<font color="blue">NIET-THUIS - Er is niemand Thuis - Het is donker - Sfeerlicht gaat aan!!</font>')
    elseif (otherdevices['Vakantie'] == 'On' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 0) then
        commandArray['Slaapkamer bedlamp']='On'
        commandArray['Slaapkamer bedlamp']='On' AFTER 10
        print('<font color="blue">VAKANTIEMODE - Er is niemand Thuis - Het is donker - Licht beneden & boven gaan aan -- TV gaat aan!!</font>')
if devicechanged[presence_switch] then
    if (otherdevices[presence_switch] == 'Off' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 1) then
		commandArray['PowerOff']='On'
        print('<font color="blue">WEGGAAN - De laatste persoon heeft heeft het huis verlaten- Het is donker - Sfeerlicht gaat aan !!</font>')
    elseif (otherdevices[presence_switch] == 'On' and otherdevices['Vakantie'] == 'Off' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 2) then
        commandArray['Group:Huiskamer']='On' AFTER 10
        print('<font color="blue">THUISKOMEN - Het is donker en er komt iemand thuis - Lichten gaan aan!!</font>')
if devicechanged[Vakantie_timer] then
    if (otherdevices['Vakantietimer'] == 'Off' and otherdevices['Vakantie'] == 'On' and otherdevices[isdark_switch] == 'On' and vSchemer_licht_aan == 2) then
        commandArray['Slaapkamer bedlamp']='Off'
        commandArray['Slaapkamer bedlamp']='Off' AFTER 10
        print('<font color="blue">VAKANTIEMODE - Er is niemand Thuis - Slaapstand actief - Alle lichten gaan uit!!</font>')
Now comes the error in my my log:
2016-06-27 20:52:01.862 Error: EventSystem: in script_device_verlichting: [string "local presence_switch = 'IemandThuis' ..."]:17: syntax error near '15'
I can't seem to fix this problem. When I change the local switches for the real name switches the error seems so change to
2016-06-27 20:58:32.243 Error: EventSystem: in script_device_test2: [string "vSchemer_licht_aan = tonumber(uservariables['..."]:12: syntax error near '15'
Anyone recogines this as a Synology specific error? Or is it me completely missing something?
Thanks in advance
- Stefan
jvdz
Domoticz version: 4.107
Re: Help needed -- lua script on Synology
Post by jvdz »
Line 17 should read:
        commandArray['Group:Huiskamer']='Off AFTER 15'
Same issue on lines 32,40,43,60,72
Jos
steef84
Post by steef84 »
Very nice find, didn't spot that one! Thanks. Fixed it and now the script partly works. When for example my IemandThuis switch changes the lua script comes partly in actions and trigger some actions. However it throws an error at the log.
2016-06-27 22:48:00.289 Error: EventSystem: in script_device_verlichting: [string "vSchemer_licht_aan = tonumber(uservariables['..."]:9: attempt to index global 'devicechanged' (a nil value)
Using now this script_device_verlichting.lua file
function sleep(n)
if devicechanged['State - IsDonker'] then
    if (otherdevices['State - IsDonker'] == 'Off' and otherdevices['Zon op-onder'] == 'Off' and vSchemer_licht_aan >= 1) then
    elseif (otherdevices['IemandThuis'] == 'On' and otherdevices['Vakantie'] == 'Off' and otherdevices['State - IsDonker'] == 'On' and vSchemer_licht_aan == 0) then
    elseif (otherdevices['IemandThuis'] == 'Off' and otherdevices['Vakantie'] == 'Off' and otherdevices['State - IsDonker'] == 'On' and vSchemer_licht_aan == 0) then
        commandArray['Scene:Sfeertje']= 'On AFTER 10'
    elseif (otherdevices['Vakantie'] == 'On' and otherdevices['State - IsDonker'] == 'On' and vSchemer_licht_aan == 0) then
        commandArray['Slaapkamer bedlamp']='On AFTER 10'
if devicechanged['IemandThuis'] then
    if (otherdevices['IemandThuis'] == 'Off' and otherdevices['Vakantie'] == 'Off' and otherdevices['State - IsDonker'] == 'On' and vSchemer_licht_aan == 1) then
    elseif (otherdevices['IemandThuis'] == 'On' and otherdevices['Vakantie'] == 'Off' and otherdevices['State - IsDonker'] == 'On' and vSchemer_licht_aan == 2) then
if devicechanged['Vakantietimer'] then
    if (otherdevices['Vakantietimer'] == 'Off' and otherdevices['Vakantie'] == 'On' and otherdevices['State - IsDonker'] == 'On' and vSchemer_licht_aan == 2) then
        commandArray['Slaapkamer bedlamp']='Off AFTER 10'
- Stefan
steef84
Post by steef84 »
My error is fixed with this post: viewtopic.php?f=23&t=12568#p90073 Thanks again Jos!
- Stefan
