Whatsapp install problem
Ritmeester
Post by Ritmeester »
I have a problem with installing WhatsApp message system in Domoticz.
I have a test system with a clean install of Domoticz 3.4834. After install I did expand the filesystem and ran de OS updates with:
sudo apt-get update
sudo apt-get upgrade
After this I update Domoticz to latest beta version.
Then I start to install the WhatsApp tools according to the page on Instructables link in the Wiki page.
My WhatsApp registration went very well without errors and I get a password.
After installing and creating the config file I must start de CLI client to test a message.
And here is goes wrong and I don’t know what to do now:
pi@raspberrypi:~/yowsup$ cd /home/pi/yowsup
pi@raspberrypi:~/yowsup$ yowsup-cli demos --yowsup --config config
  File "/usr/local/bin/yowsup-cli", line 4, in <module>
    __import__('pkg_resources').run_script('yowsup2==2.5.0', 'yowsup-cli')
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2876, in <module>
    working_set = WorkingSet._build_master()
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 449, in _build_master
    ws.require(__requires__)
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 745, in require
    needed = self.resolve(parse_requirements(requirements))
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 645, in resolve
    requirements.extend(dist.requires(req.extras)[::-1])
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2401, in requires
    dm = self._dep_map
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2386, in _dep_map
    for extra, reqs in split_sections(self._get_metadata(name)):
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2841, in split_sections
    for line in yield_lines(s):
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2078, in yield_lines
    for ss in strs:
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 2415, in _get_metadata
    for line in self.get_metadata_lines(name):
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1413, in get_metadata_lines
    return yield_lines(self.get_metadata(name))
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1405, in get_metadata
    return self._get(self._fn(self.egg_info, name))
  File "/usr/lib/python2.7/dist-packages/pkg_resources.py", line 1514, in _get
    with open(path, 'rb') as stream:
IOError: [Errno 13] Permission denied: '/usr/local/lib/python2.7/dist-packages/protobuf-3.0.0b3-py2.7.egg/EGG-INFO/requires.txt'
sincze
Domoticz version: 2024.4
Re: Whatsapp install problem
Post by sincze »
mmm interesting.
Should work indeed.
http://www.instructables.com/id/WhatsAp ... /?ALLSTEPS
I do see in your log:
But I guess you already tried this command with sudo??
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Rafik89
Post by Rafik89 »
It should be like this:
./yowsup-cli demos --yowsup --config config
MarcosFields
Post by MarcosFields »
If you have problems installing whatsapp then try switching over to using gb whatsapp at techbigs. The app lets you text and call your loved ones for free.
