No parameters on FGMS-001
Larsja
Domoticz version: V2.3530
Post by Larsja »
Im trying to get my Fibaro FGMS-001 to work, using RPi2 and UZB-1. I already have one FGMS-001 working.
But when i add this one, i dont get any parameters on the hardware/uzb-1 tab. And it comes up as unknown. But under the Device tab i get all the sensors (temp,lux,motion etc) Tried removing and adding it, tried waking it up, so i can receive current parameter settings, cant even change the name on the sensor.
jvdz
Domoticz version: 4.107
Re: No parameters on FGMS-001
Post by jvdz »
I do not see any 0801 - 1001 device in the manufacturer_specific.xml list. Maybe your previous device is a 0800 - 1001?
You could try copying the line of the previous version and update the device number assuming it has the same devices or maybe the current beta with the latest open zwave has the support for this device build in already. the file can be found in domoticz\config
Jos
Larsja
Post by Larsja »
Thanks, that did the trick with copying the line for the 0800 and pasting it and changing it to 0801 in the xml file.
Thumbs up mister :D
gizmocuz
Post by gizmocuz »
Could you write this in the openzwave forum, as then it gets supported in their next update
Larsja
Post by Larsja »
Done
niceandeasy
Domoticz version: 3.8153
Post by niceandeasy »
I have this specific FGMS-001 version 0x1001 0x0801. I'm on the beta channel. It is supported (thanks Larsja), but sadly, not very well supported. There is the usual alarm level/type, temp/hum, lux. But PIR and tamper/vibration is unclear.
There's a General, a Burglar and a Sensor, in Domoticz I see these as On/Off light switches.
The Burglar switches on on PIR and tamper events. The state of the General and the Sensor changes sometimes. I could not determine what they mean, yet.
The OZW control panel shows numeric values for burglar while Domoticz shows on/off. And it's not always 0 or 255.
So, any help on how to proceed is very welcome. I already tried configuring the FGMS-001 and woke it up so it receives the config. But that does not really help.
My goal is to have my FGMS-001 tamper-detection configured as a vibration sensor and have Domoticz logging the numeric value of it when vibrations occur.
