delta t lua
Posted: Friday 24 June 2016 22:28
by tiga
what is going wrong??
i have the clean temp values for the temp inside and outside.
i want to calculate the delta.....and for now print it.
local tempbinnen = 'binnen temperatuur'--only temp value from inside
local tempbuiten = 'buiten temp wu'--only temp valu from outside
delta = tempbuiten - tempbinnen
print (delta)
do i miss something?
Re: delta t lua
Posted: Friday 24 June 2016 22:36
by jvdz
You are trying to calculate with 2 strings as the error indicates.
This works fine:
local tempbinnen = 20 --only temp value from inside
local tempbuiten = 10 --only temp valu from outside
print(delta)
Jos
Re: delta t lua
Posted: Friday 24 June 2016 22:48
by tiga
thanks for your answer jos.
the answer is -10
but i made up 2 dummy devices in temperature that i want to subtract from eachother.that must be possible right?
Re: delta t lua
Posted: Friday 24 June 2016 23:07
by jvdz
Sure. Could be that a string is returned in which case you simple convert it to a number with tonumber() like:
local tempbinnen = '20'--only temp value from inside
local tempbuiten = '10'--only temp valu from outside
delta = tonumber(tempbuiten) - tonumber(tempbinnen)
print(delta)
Jos
Re: delta t lua
Posted: Friday 24 June 2016 23:14
by georgesattali
here's my proposal :
local tempbinnenDeviceName = 'binnen temperatuur'--only temp value from inside
local tempbuitenDeviceName = 'buiten temp wu'--only temp valu from outside
local tempbinnen = otherdevices_temperature{tempbinnenDeviceName]
local tempbuiten = otherdevices_temperature{tempbuitenDeviceName]
print (delta)
See you,
GD
Re: delta t lua
Posted: Friday 24 June 2016 23:45
by tiga
thanks you helped me a lot!!!!!!
i am very thankfull.
Re: delta t lua
Posted: Saturday 25 June 2016 21:47
by tiga
ok...this is how my script looks now:
local tempbinnen = otherdevices_temperature[tempbinnenDeviceName]
local tempbuiten = otherdevices_temperature[tempbuitenDeviceName]
print (delta)
print(tempbinnen)
print(tempbuiten)
commandArray = {['Variable:deltaT'] = tostring(delta)}
the reason sor this script is to generate a uservariable Delta with a ONE decimal value....but....
this comes up:LUA: -7.3999996185303 a number with 13 decimals.
thats a little to much so i added print tempbinnen and print tempbuiten to figure out what couses it.this is the log:
2016-06-25 21:39:00.080 LUA: -7.3999996185303 (delta)
2016-06-25 21:39:00.080 LUA: 23 (temp binnen) (this is an exact 23 but normaly 1 decimal value)
2016-06-25 21:39:00.080 LUA: 15.60000038147 (temp buiten)
so tempbuiten was the issue i thougt.this is a value from weather underground that i split up.
but when i print the value from this device in my split script it prints out a nice 15.6
it is a mistery to me why this happens.
can i make it a one decimal value again in my delta variable?
thanks
Re: delta t lua
Posted: Saturday 25 June 2016 22:16
by jvdz
This example contains a Round function that will help rounding values:
function Round(num, idp)
	return tonumber(string.format("%." ..(idp or 0).. "f", num))
local tempbinnen = 23.0 --only temp value from inside
local tempbuiten = 15.60000038147 --only temp valu from outside
--~ local tempbinnenDeviceName = 'binnen temperatuur'--only temp value from inside
--~ local tempbuitenDeviceName = 'buiten temp wu'--only temp valu from outside
--~ local tempbinnen = otherdevices_temperature[tempbinnenDeviceName]
--~ local tempbuiten = otherdevices_temperature[tempbuitenDeviceName]
print(delta)
delta = Round(delta, 1)
print(delta)
print(tempbinnen)
print(tempbuiten)
--~ commandArray['Variable:deltaT'] = tostring(delta)}
Think the commented line is the correct format for updating with the commandArray[] table.
Jos
Re: delta t lua
Posted: Saturday 25 June 2016 23:00
by tiga
thanks jos that did the job.script looks like this now
print (delta)
but now i did a simple test:
and !!tada!! nothing happens.... :cry:
lua script runs on time so updates my deltaT variable every minute.
but when i correct the user variable with the same value by hand then it works......
how is that possible????
Re: delta t lua
Posted: Saturday 25 June 2016 23:08
by jvdz
Funny, you are the second one asking this today. See my answer here: http://www.domoticz.com/forum/viewtopic ... 490#p89503
Jos
Re: delta t lua
Posted: Saturday 25 June 2016 23:18
by tiga
ok that makes it a little bit complicated for me.so if understand correctly i have to update my user variable via json with a variable number....delta t
can you help me with that line please jos?
i realy want to use blockly from here on with my delta value :)
i know a little about json but what do i have to fill in here : vvalue=.?.?.?.
Re: delta t lua
Posted: Saturday 25 June 2016 23:26
by jvdz
Can't test but something like this should be close:
commandArray['OpenURL']='127.0.0.1/json.htm?type=command&param=updateuservariable&vname=deltaT&vtype=0&vvalue='..tostring(delta)
Coding is fun isn't it? :)
Jos
Re: delta t lua
Posted: Saturday 25 June 2016 23:46
by tiga
ja it is is fun if it works :lol:
im not that good but this works jos:
commandArray['OpenURL']='192.168.0.115:8080/json.htm?type=command&param=updateuservariable&vname=deltaT&vtype=1&vvalue='..tostring(delta)
perfect man jou helped me a lot thanks!!!!!
Re: delta t lua
Posted: Saturday 25 June 2016 23:51
by jvdz
ha yea, you needed a float since you have decimals. Just thought I make a generic function for my general function lua file so I can also use this going forward.
-- Update variable and ensure the Event system will trigger the variable event scripts
-- param2; Vartype =
-- 		0 = Integer, e.g. -1, 1, 0, 2,10
-- 		1 = Float, e.g. -1.1, 1.2, 3.1
-- 		2 = String
-- 		3 = Date in format DD/MM/YYYY
-- 		4 = Time in 24 hr format HH:MM
function UpdateVariable(Varname, Vartype, Value)
	if Varname == nil then
		print("function UpdateVariable param:Varname is nil")
		return
		print("function UpdateVariable param:Vartype is nil")
		return
		print("function UpdateVariable param:Value is nil")
		return
	commandArray['OpenURL'] = '127.0.0.1/json.htm?type=command&param=updateuservariable&vname='..Varname..'&vtype='..Vartype..'&vvalue='..tostring(Value)
So you can simply call it in your script like:
UpdateVariable("deltaT", 1, delta)
Enjoy,
Jos
Re: delta t lua
Posted: Sunday 26 June 2016 23:02
by commodore white
You REALLY should check out http://www.domoticz.com/forum/viewtopic ... 23&t=10834. You'll find it a whole lot easier to access device values rather than mess with JSON.
To help with printing out floating point variables, I use a slightly modified print statement defined thus:
local printf = function(s,...) print(s:format(...)) end
You can still construct strings to print the old way but you can also print values and have the print function honour printing floating point numbers to different precisions and do string alignment. This I got from the LUA string formating library:
s:format(e1, e2, ...)
Create a formatted string from the format and arguments provided. This is similar to the printf("format",...) function in C. An additional option %q puts quotes around a string argument's value.
c, d, E, e, f, g, G, i, o, u, X, and x all expect a number as argument.
q and s expect a string.
> = string.format("%s %q", "Hello", "Lua user!") -- string and quoted string
Hello "Lua user!"
> = string.format("%c%c%c", 76,117,97) -- char
Lua
> = string.format("%e, %E", math.pi,math.pi) -- exponent
3.141593e+000, 3.141593E+000
> = string.format("%f, %g", math.pi,math.pi) -- float and compact float
3.141593, 3.14159
> = string.format("%d, %i, %u", -100,-100,-100) -- signed, signed, unsigned integer
-100, -100, 4294967196
> = string.format("%o, %x, %X", -100,-100,-100) -- octal, hex, hex
37777777634, ffffff9c, FFFFFF9C
Try it. You'll like it!
Re: delta t lua
Posted: Monday 27 June 2016 9:28
by jvdz
commodore white wrote:You REALLY should check out http://www.domoticz.com/forum/viewtopic ... 23&t=10834. You'll find it a whole lot easier to access device values rather than mess with JSON.
Agree it is a pretty nice project, although I prefer coding myself as that is part of the fun for me. :)
Either way, it is still LUA scripting so will have the same limitation as I've pointed out earlier.
Jos
