Custom Sensor - Cost
Posted: Thursday 23 June 2016 12:02
by iserialize
Hi, i am using the latest stable build and would like a custom sensor to log spot pricing for power from my energy supplier every x minutes. I have this working using a text sensor but would ideally like to display a graph which shows the price across the day and also set up notifications if the price goes above or under a certain threshold.
Issue with the text sensor is that the data is not graphed and i cannot set up notifications from within the UI. Iam i stuck with using the text sensor?
Re: Custom Sensor - Cost
Posted: Thursday 23 June 2016 12:07
by gizmocuz
Upgrade to the beta version, add a dummy hardware device (if you have not done so already)
Then press the 'create virtual sensor', choose the new 'custom' type, enter the legend text
Posted: Thursday 23 June 2016 20:30
by iserialize
works perfectly. Thanks for the info
Posted: Monday 09 January 2017 23:16
by 1kohm
iserialize wrote:Hi, i am using the latest stable build and would like a custom sensor to log spot pricing for power from my energy supplier every x minutes. I have this working using a text sensor but would ideally like to display a graph which shows the price across the day and also set up notifications if the price goes above or under a certain threshold.
I'm having the same request to create dummy sensor that could show me actual costs based on my energy usage.
Now it's only available under device report.
- cost.PNG (28.29 KiB) Viewed 2251 times
How did you achieve that in costum sensor?
My goal is to reset cost data every two months - I got pricing from my energy supplier every two months.
