slow down device update
tiga
Post by tiga »
i have a little problem.
i have an inside temp sensor but this one hase a humidity sensor as well.
i wanted a "switch"with only the temperature.so i created a virtual one.im not good with lua so i coppied a script to do that.
this is normally used to split weather underground, that is updated every 10 minutes.
local sensorwu = 'temperatuur woonkamer' --name of the sensor that gets created when you add the WU device (and that contains multiple values like temperature, humidity, barometer etc)
local idxt = 114 --idx of the virtual temperature sensor you need to change this to your own Device IDx
if devicechanged[sensorwu] then
        sWeatherTemp, sWeatherHumidity = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+)")
        sWeatherTemp = tonumber(sWeatherTemp)
        commandArray[1] = {['UpdateDevice'] = idxt .. '|0|' .. sWeatherTemp}
now the problem is my temp sensor updates every 30 seconds....can i let this update (slow down) to once every 5 minutes??
that is more then enough for my use.
SweetPants
Re: slow down device update
Post by SweetPants »
No matter what you do, the script is fired every 30 sec anyway. The only way to slow it down is by the sensor itself
Verstuurd vanaf mijn HTC Desire 610 met Tapatalk
