Dear all,
Been busy getting my POPP KFOB-C working within domoticz for weeks now and I don't get it working. I hope on the forum there is somebody who can help me.
Setup: Raspberry Pi and AEON Labs Zwave Stick.
I want to include the KFOB-C of POPP in order to use the for buttons just to trigger a switch, but I don't get it working. Any ideas, help, suggestions would be great.
Thx,
Jerre
POPP KFOB-C
- gizmocuz
Re: POPP KFOB-C
use the forum search option (it is on the top right) and enter kfob as search keyword...
Jerre
Re: POPP KFOB-C
I already did, that's why I created this topic, none of the find topics where providing me the solution. if you know which does, please guide me to it
Sypher
Re: POPP KFOB-C
Jerre, have you been able to get it to work? I am only able to include it and one device (with a level) appears. The led on the remote however shows red for each command sent, which is - according to the manual - "failure". Domoticz recognizes it, and its settings yet somehow it doesn't send its signals to the stick?
Larsja
- Domoticz version: V2.3530
Re: POPP KFOB-C
does this help? I used it with the Popp wall2c, and after some plundering, (actually used the adress in the example instead of the adress it had on my system... DOH!)
https://www.domoticz.com/wiki/Popp_Kfob
Sypher
Re: POPP KFOB-C
Even with that I cannot get it to work. I can pair it (either secure or unsecure mode). But only one device shows up: "level". Clicking, doubleclicking, tripleclicking the buttons doesn't add anything to the Domoticz logs and also the led remains red instead of green.Larsja wrote:does this help? I used it with the Popp wall2c, and after some plundering, (actually used the adress in the example instead of the adress it had on my system... DOH!)
Jerre
Re: POPP KFOB-C
Same here, I still don't get it work
cyclops1982
- Target OS: -
Re: POPP KFOB-C
So, the wiki helped me a lot, but now i can only 'Send scene'. That allows me to start a scene.
I would like to be able to just 'toggle a switch' with the buttons (single click = on, double click = off). As i understand it, this should be possible.
I can see the 'Basic set' coming in, but the device does not show up inside domoticz. Why is this?
Does domoticz not handle a basic set command?
BuzzDoet
- Domoticz version: 2022.1
Re: POPP KFOB-C
Same here: pairing Ok but I can not get it to work (red flashes with each key pressed, nothing in Domoticz log).
Any news in the meantime?
