No WLAN after sudo apt-get upgrade
OCB73
Domoticz version: 3.4834
Post by OCB73 »
Good morning!
Today i ve done an update/upgrade on my raspi.
After restarting no wlan-connection is established.
I ve checked /etc/network/interfaces but all is like
it was. Any ideas?
Thats my /etc/network/interfaces:
iface lo inet loopback
iface eth0 inet dhcp
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wpa-ssid "xxxxx"
wpa-psk "xxxxx"
Oliver
georgesattali
Re: No WLAN after sudo apt-get upgrade
Post by georgesattali »
Hello Oliver,
here's the content of my /etc/network/interfaces (I never changed it, it's the default), but instead of modifying /etc/network/interfaces, I modify /etc/wpa_supplicant/wpa_supplicant.conf (second file below) - I followed explanations found on Internet.
pi@raspberrypi:~ $ cat /etc/network/interfaces
# interfaces(5) file used by ifup(8) and ifdown(8)
# Please note that this file is written to be used with dhcpcd
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'
# Include files from /etc/network/interfaces.d:
source-directory /etc/network/interfaces.d
auto lo
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
allow-hotplug wlan1
iface wlan1 inet manual
pi@raspberrypi:~ $ sudo cat /etc/wpa_supplicant/wpa_supplicant.conf
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
country=FR
network={
    ssid="put your ssid here"
    scan_ssid=1
    key_mgmt=WPA-PSK
    psk="put your password here"
NB : country=FR has been added automatically by sudo raspi-config (Internationalization options / Wifi country).
Regards,
GD
OCB73
Post by OCB73 »
Hello and thx for your answer.
I will give it try and report the result.
I also did it like explained in the internet but i think there are a few way to setup the WLAN.
Are you using DHCP or a static IP?
If static, configured via your router or raspi?
Oliver
georgesattali
Hi OCB73,
I use DHCP, but I configured my box (box administration, option DHCP or DHCP serveur) so that the same IP adress is always attributed to the 'MAC Adress' of the wifi card of the raspberry).
Usually the box shows the mac adress of any equipment connected to it, you may see it also on the raspberry as the HWaddr given by the command :
ifconfig
See you,
GD
