domoticz install on orangepi does not start automaticly
Posted: Friday 17 June 2016 7:56
Hi there,
i want to use a orangepi with domoticz. I have installed raspbian on the orangepi and used this install wiki everyhting is good, but it will not start automaticly. When i go to the ip adress it keeps saying Domoticz offline.
The only thing i am not sure about are these settings.
The username for orangepi is orangepi, so i use DAEMON=/home/orangepi/domoticz/domoticz
then when i am finished i use this command
then it shows nothing and just reveales a new line...
When i want to check the status of the install to see if it is running i use this command
But again, it does nothing, it just shows a new line. When i try this on a raspberry pi it gives me some line where it states that domoticz is up and running.
I am no programmer, so i know there is a mistake somewhere....i just need to be pointed in the right direction.
Hope someone can help.
Iwan
USERNAME=pi
DAEMON=/home/$USERNAME/domoticz/$NAME
DAEMON_ARGS="-daemon -www 8080"then when i am finished i use this command
sudo service domoticz.sh startWhen i want to check the status of the install to see if it is running i use this command
sudo service domoticz.sh statusI am no programmer, so i know there is a mistake somewhere....i just need to be pointed in the right direction.
Iwan
