Help with pulling snmp from device
kllngtme
Post by kllngtme »
Noob here, go easy!
I'm trying to use Domoticz to pull snmp from another device on my network. I have the OID's I need from doing an smpwalk of the device. That's pretty much as far as I've gotten. The device I'm discussing has simple, temperature and humidity sensors that I'm trying to gather and pull into domoticz.
Here are the OID's I'm working with. Can anyone give me any information on where to get started. Is there a noobie guide for idiots like me getting started with Domoticz? I really have no idea where to even begin.. Any information would be great as I'm struggling with this..
OID=.1.3.6.1.4.1.20916.1.6.1.1.1.1.0, Type=Integer, Value=6708
OID=.1.3.6.1.4.1.20916.1.6.1.1.2.1.0, Type=OctetString, Value=Basement
OID=.1.3.6.1.4.1.20916.1.6.1.2.1.2.0, Type=Integer, Value=6967
OID=.1.3.6.1.4.1.20916.1.6.1.2.1.6.0, Type=OctetString, Value=Living Room
OID=.1.3.6.1.4.1.20916.1.6.1.2.2.2.0, Type=Integer, Value=9816
OID=.1.3.6.1.4.1.20916.1.6.1.2.2.3.0, Type=Integer, Value=4117
OID=.1.3.6.1.4.1.20916.1.6.1.2.2.4.0, Type=Integer, Value=10558
OID=.1.3.6.1.4.1.20916.1.6.1.2.2.6.0, Type=OctetString, Value=Attic
The last 4 oid's are:
Temperature OID
Humidity OID
Heat Index OID
Location OID
Otherwise, the first 2 are easily understood as Temperature and location oid's.
kllngtme
Re: Help with pulling snmp from device
Post by kllngtme »
bump... anyone?
niceandeasy
Domoticz version: 3.8153
Post by niceandeasy »
Look here: https://www.domoticz.com/wiki/NAS_Monitoring
You'll need to port this to Windows and adapt it for reading your snmp device.
(or switch to Linux / Raspberry)
kllngtme
Post by kllngtme »
yea I was looking at that page and had a feeling it might be it but was hoping there was an easier route somehow already built in to domoticz.
I'll have to rethink this.. It's between setting up a VM or getting a pi. or using my Synology nas.. So many options...
pepijn
Post by pepijn »
I use Node RED to extract SNMP data from some devices and put it into Domoticz.
kllngtme
Post by kllngtme »
pepijn wrote:I use Node RED to extract SNMP data from some devices and put it into Domoticz.
Is this for use with Windows?
