Lua & commandArray['OpenURL']
riro
Post by riro »
Since 10th of May I cant use OpenURL from a Lua-script.
I'm running on a Synology DS-415+ with version 3.5228 right now.
I really need to use this since OpenURL triggers (via a simple webservice) on/off on multiple devices connected to another machine...
Anyone who knows what the issue might be?
(can't see any error in the log)
simonrg
Domoticz version: 3.8807
Re: Lua & commandArray['OpenURL']
Post by simonrg »
The most likely explanation is that something is wrong with your code, so if you post it then somebody might spot the problem.
riro
Post by riro »
Well probably not... since the code worked just fine before.
Did a test with a small piece of code with more or less a OpenURL only, and that didn't connect to the recieving webserver.
Keptenkurk
Post by Keptenkurk »
Could it be the synology? Had a networking issue with my 109 last month. The routing process had failed causing weird connectivity problems. A reboot of the Synology fixed it.
/paul
riro
Post by riro »
I think it's a combo of DSM6 and Domoticz...
With DSM6 a lot of security where added, might be that Domoticz is using something thats restricted...
