I have put together a clapper based on the mysensors knock node.
https://www.mysensors.org/build/knock
Its working and is showing as a lightswitch in domoticz, 3 claps = on, 3 claps = off.
I want to controll 1 specific light with the clapper, but the same light is controlled by 2 different scenes and 1 remote controll (all through domoticz).
I have tried to set a blockly event to control the light but it enters a loop that turn my light on and off.
Any idea on how to controll the light with the clapper?
Using a "clapper" to turn on/off lights
- bizziebis
- Domoticz version: 3.8805
Re: Using a "clapper" to turn on/off lights
You can create a new Group and add the switch you would like to switch on/off. Then add the clapper as activation device for that group.
Derik
- Domoticz version: BETA
dear,
That is the option that is my wife always talking about.
klap klap lichten aan...
Please can you tell me the details..
Thanks for your reply, that is exactly what i was looking for.bizziebis wrote:You can create a new Group and add the switch you would like to switch on/off. Then add the clapper as activation device for that group.
I am using an arduino nano with a microphone/sound detector and MySensors code.Derik wrote:dear,
I have connected a nrf24l01 wireless chip to the arduino so it can send on/off commands to domoticz.
If you dont already have any mysensor nodes you also need to set up a gateway, so the nodes can talk to domoticz or to a MQTT broker.
I connected a nrf24 chip directly to my Raspberry pi with a gateway script running but you can also use an ESP8266 + nrf24 chip to get a wireless mysensor gateway.
The clapper node (build instructions and parts, you dont need the speaker/buzzer)
The gateway
https://forum.mysensors.org/topic/2437/ ... al-gateway
I guess it should be possible to add a microphone directly to the RPi GPIO pins so that you can skip the gateway and mysensors, but i need to have several of them around the house so its nice to have the wireless option that mysensors provide.
Derik
i have mysensors gateway.
And i now how to build the mysensors....
Only can i have more options like 2 claps x, 3 claps y and 4 claps z...?
Or only 1 domoticz switch?
