Page 1 of 3
Zwave network toooooo complicated ?
Posted: Thursday 02 June 2016 15:57
by pascalspits
doesn't this look tooooooo complicated ?
have I done something wrong ?
do I need to adjust some settings ?
How can I simplify my network ?
I'm worried about it ...
Re: Zwave network toooooo complicated ?
Posted: Thursday 02 June 2016 16:09
by Egregius
What's the problem? What's too complicated?
Looks pretty normal, wait until you have some more devices, then you see nothing anymore.
Posted: Thursday 02 June 2016 18:17
by jvdz
That is what one calls a MESH network :)
Posted: Thursday 02 June 2016 23:23
by Plaagje
Pascal, explain your question?!
Sent from my Nexus 5X using Tapatalk
Posted: Friday 03 June 2016 10:52
by pascalspits
I thought there were too many connections going on, making the network unstable maybe ?
... that's why I was worried, but apparently this is normal and I shouldn't worry about it ?
Posted: Friday 03 June 2016 11:21
by jvdz
As said, zwave creates a mesh network with alternative routes to route the information back to the controller. This should make it more stable then with single routes. Maybe a nice read to understand the basics: http://www.vesternet.com/resources/tech ... e-networks
Jos
Posted: Friday 03 June 2016 13:52
by Egregius
With 49 nodes it look's like this :mrgreen:
Posted: Friday 03 June 2016 16:24
by StanHD
Spirograph :lol:
Posted: Sunday 05 June 2016 11:17
by mvveelen
Mespr0n :D :D
@Egregius: this network looks great. Maybe in due time I'll have something similar.
@pascalspits: your networks looks great too. Don't make the mistake to turn polling on, THAT will slow your network down....
Posted: Saturday 11 June 2016 19:19
by Ron
In my configuration the controller doesn't have any connection to other modules, although al seems to work fine.
This has always been the case, what does this mean and did i confiigure something wrong?
Posted: Saturday 11 June 2016 19:26
by Ron
Mijn netwerk.
Posted: Tuesday 14 June 2016 23:04
by hamish
Yeah... I think there's an issue somewhere. Because I have two controllers and 6 nodes. The two controllers are on separate raspberry pi-2's. The first controller (RaBerry) see this...
Screen Shot 2016-06-14 at 21.57.55.png (344.12 KiB) Viewed 6266 times
The second controller (Aeotec G5 USB) sees this...
Screen Shot 2016-06-14 at 21.59.48.png (302.72 KiB) Viewed 6266 times
Given that it's one network. Both graphs SHOULD look the same. But they don't... They also don't quite match the node status. For example the RaZBerry (Node001) graph shows that the network is almost in two parts. With Node005 acting as the relay between one side and the other. Yet the RaZBerry more often than not shows Node005 as DEAD. The second controller (Node004) on the other hand can see Node005 fine...
Very strange... I'm not sure I understand why the graphs and device comms lists should look so different on the same network.
Posted: Tuesday 14 June 2016 23:41
by pascalspits
This morning Domoticz asked me to update ... I agreed
This is what I discover this evening ...
suddenly, all by itself !
why ? how ?
Posted: Wednesday 15 June 2016 12:10
by juankar
You can use Zwave Control Panel to see the topology as a table, perhaps it's easier than this beatiful and coloured picture.
Posted: Wednesday 15 June 2016 12:25
by pascalspits
my question is : how can it automatically go from this
to this
only by updating Domoticz ?
NOTHING has changed to the controllers, dimmers, sensors ... to the network itself
how do these connections suddenly appear in the group list and where are all the connections in the graph view ?
behavior in the hous was crazy ... garage licht made heater turning on and all kinds of crazy connections !
I cleaned it up (by removing all "weird" nodes from the groups) and now it looks like this ... everything seems to work, but still the pie-graph doesn't show any connections ... very weird
I'm running Domoticz on RasPi2 with Fibaro RGBW dimmers and Fibaro multi-sensors and an AEOTEC stick
Posted: Wednesday 15 June 2016 12:30
by Egregius
The group associations explain the weird behavior.
But why the links are all gone? I really can't say, I assume you waited for the screenshot until all nodes are queried aka blue settings button?
Posted: Wednesday 15 June 2016 12:34
by pascalspits
Yep, all nodes are there ... look !
Posted: Wednesday 15 June 2016 12:45
by Egregius
And restart or network heal doesn't change anything?
Posted: Wednesday 15 June 2016 14:00
by pascalspits
network heal froze/crashed the system, so I rebooted the Pi
after rebooting I check the network information and BOOM !
again it made a bunch of crazy connections all by itself ...
(by the way, this "trap en hall" is a RGBW dimmer from Fibaro)
what am I doing wrong ??
Posted: Saturday 23 July 2016 12:35
by pascalspits
last few weeks again started to notice strange behaviour ... for example : bedroom blinds going up or down when switching on bathroom lights ... ?!
I did a soft reset controller and then these weird Zwave connections appeared again ...
this keeps puzzling me ... where do these crazy connections come from all by theirself ?!
What am I doing wrong here ?
