Onkyo Volume Switch
Lyrex
Onkyo Volume Switch
Post by Lyrex »
hey guys,
is ist possible to create a volume slider for my onkyo avr? Im using the python implementation auf eiscp and atm im using two switches as push on buttons with this lua script:
if devicechanged['Volume Up']=="On" then
   onkyo_change('volume:level-up')
   if devicechanged['Volume Down']=="On" then
      onkyo_change('volume:level-down')
Reasons:
1. the push on buttons are very sluggish
2. With a slider i can move to the position i want and the receiver is doing stuf..
Additional Info:
its possible to set the volume directly withe volume:0-100 and you can get the current volume with volume:query.
Lyrex
Re: Onkyo Volume Switch
Post by Lyrex »
Did no one ever done it? :/
Skippiemanz
Domoticz version: 4.10233
Post by Skippiemanz »
Maybe with the multi selector switch?
Verstuurd vanaf mijn SM-G925F met Tapatalk
Lyrex
Post by Lyrex »
What i tried:
if i create a virtual sensor as Selector Switch => edit the Switch and change the type from Selector Switch to Dimmer (i realy want a slider :evil: ) the switch is not editable oder deletable anymore... The point is.. MAYBE (i did not test it yet) i can use this wonky created switch for what i want but im unable to edit or delete this button in the future.
I saw via google (i search a solution since a week..) pictures with what i want. A slider named Volume for avr's but no one say how this is possible :lol:
DarkFoxDK
Post by DarkFoxDK »
I've done this with my Bravia TV. I can't get the current volume for it, so I've had to make it change the volume relatively.
The only way I've found as well, is the Selector switch method. You just gotta get all the settings set before you change it to Dimmer. You can delete it from the Devices page, if need be. My main issue with it, is that the slider doesn't show up for it, on the floorplan. :-(
As for the volume changing, I've solved it in this way:
remoteScript = '/home/pi/domoticz/scripts/remote.sh'
for deviceName,deviceValue in pairs(devicechanged) do
    if (deviceName=='Bravia TV') then
        if (deviceValue == 'On') then
            commandArray['TV'] = 'Set Level: 50 %'
            commandArray['TV'] = 'Off'
    if (deviceName=='TV') then
        deviceSValue = otherdevices_svalues["TV"]
        if (deviceValue == 'Off') then
            if (otherdevices['Bravia TV'] ~= 'Off') then
                os.execute(remoteScript..' Mute &')
        elseif (tonumber(deviceSValue) ~= 50) then
            if tonumber(deviceSValue) < 50 then
                times = 50 - deviceSValue
                os.execute(remoteScript..' VolumeDown '..times..' &')
            elseif tonumber(deviceSValue) > 50 then
                times = deviceSValue - 50
                os.execute(remoteScript..' VolumeUp '..times..' &')
(Bravia TV is a pinger that pings the TV's IP. TV is the virtual switch.)
If you don't need to display on/off status, just remove the Bravia TV bits.
Lyrex
Post by Lyrex »
hm okay then i will do it like you as well. Thank you :)
