I am interested in using following module:
http://denkovi.com/smartden-lan-etherne ... rrencyID=2
This is an 16 port ethernet relay.
Purpose would be to have 16 switches (or combine some of them) in Domoticz, so that I can drive those switches using domoticz (and adding a timer later on).
Each switch would have to send an HTTP get request to the device to switch it on or off.
You can also get the state back from each relay etc (it would be good to check if the relay was really opened or closed!)
Which http request to send can be found here:
http://denkovi.com/Documents/smartDen-I ... Manual.pdf
I am a programmer, so I would be interested to add it to the compatible hadware, but I would need some basic hooks and examples to do this. So if somebody could show me the right direction. The developer of the HW device is of course also interested to get this working.
Kind regards,
Luc
how to add new hardware: e.g. smartDEN 16 ethernet relay
