If "message in log" then
mvveelen
Post by mvveelen »
would it be possible / handy to implement something like this:
If in the logfile a message is written which contains: "NefitEasy: Invalid data received" (you should be able to edit the exact message), then set a certain parameter / switch to a certain value / on ?
@Gizmocuz: this way you could use this to make a relais or power switch to flip whenever there is a problem with reading data from the server, right?
In this case you could power off the device for 2 seconds and then power it on.
Same applies here: can't blame a guy for trying :lol:
