Change icon on Selector Switch
Domange
Post by Domange »
Hu,
I think all is said...
I have a selector switch and the only icon I can have is an On/Off one...
Is it posible to have different icons dependeing on the current level ?
Thank you
Runs fine on ODroid N2 4Gb Ubuntu 18.04 LTS except V2020.1
keson
Domoticz version: 2021.1
Re: Change icon on Selector Switch
Post by keson »
Hi. Did you ever get solution for your question?
DAVIZINHO
Post by DAVIZINHO »
Hello, sorry for the up,
but this is a interesting question
i have a selector switch and will be very usefull if i can design a icon for value 10, other for 20, etc.... like the temperature icon.
its is posible???
Nautilus
Post by Nautilus »
No it is not possible at the moment. Some workarounds exist: viewtopic.php?f=31&t=107#p100598 look especially into this line in the lua script:
os.execute('curl -s -i -H "Accept: application/json" "http://"'..DOMO_IP..'":"'..DOMO_PORT..'"/json.htm?type=setused&idx="'..idxmoonphaseicon..'"&name=Maanfase&description=&switchtype=0&customimage="'..moonPhaseIcon..'"&devoptions=1;%20&used=true"')
So you could setup a lua script that is triggered when the level changes and it would update the icon (already uploaded) based on the new level. But I think it require you to reload the page before it is updated, not sure though. If someone has the skills, it would of course be a nice contribution to allow custom icons for all device types and as a follow up to that, a custom icon based on the switch status, at least for selector switches :)
