OverlayFS use
Posted: Friday 13 May 2016 9:49
by epierre
I open this post for I am trying to run with an OverlayFS and have somme issues with it.
I modified the proposed script for modifying readonly to readwrite in the article :
https://www.domoticz.com/wiki/Setting_u ... spberry_Pi
following a discussion from here:
but now I face an issue where I can't reboot it anymore... has anyone runnint it correctly ? what do I need to change ?
Re: OverlayFS use
Posted: Friday 13 May 2016 10:28
by epierre
One of the thread guy proposed the following instead of overlayfs:
http://k3a.me/how-to-make-raspberrypi-t ... uble-free/
Since I can't reboot in overlayfs, I may have a try here...
Re: OverlayFS use
Posted: Friday 13 May 2016 19:47
by hansrune
Sorry to hear that. Can you do as suggested in the first paragraph : mount the SD card and revert the changes ( edit /etc/fstab back to original, move the renamed directories back to where they came from) If not, where in the boot process do you end up in problems ?
Re: OverlayFS use
Posted: Saturday 14 May 2016 10:17
by epierre
hello,
I guess the main issue are ro directories and new syslogd at least.
The systemd also need to write to its /etc directory for a status I guess.
A guy that participated back a lot in 2014 on the thread is now doing another way, sign that the overlayfs would need more refinement (that I have time to right now ;-)
So reverting has been done, I had to copy back _org to the original place.
