I open this post for I am trying to run with an OverlayFS and have somme issues with it.
I modified the proposed script for modifying readonly to readwrite in the article :
https://www.domoticz.com/wiki/Setting_u ... spberry_Pi
following a discussion from here:
but now I face an issue where I can't reboot it anymore... has anyone runnint it correctly ? what do I need to change ?
OverlayFS use
- epierre
OverlayFS use
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
- epierre
Re: OverlayFS use
One of the thread guy proposed the following instead of overlayfs:
http://k3a.me/how-to-make-raspberrypi-t ... uble-free/
Since I can't reboot in overlayfs, I may have a try here...
Re: OverlayFS use
Sorry to hear that. Can you do as suggested in the first paragraph : mount the SD card and revert the changes ( edit /etc/fstab back to original, move the renamed directories back to where they came from) If not, where in the boot process do you end up in problems ?
- epierre
Re: OverlayFS use
hello,
I guess the main issue are ro directories and new syslogd at least.
The systemd also need to write to its /etc directory for a status I guess.
A guy that participated back a lot in 2014 on the thread is now doing another way, sign that the overlayfs would need more refinement (that I have time to right now
So reverting has been done, I had to copy back _org to the original place.
