Fibaro door sensor included as node, not visible in devices.
Posted: Tuesday 10 May 2016 20:55
by rf646
Hi, I have succesfully included my fibaro door and window sensors through the add node procedure. They do not appear in the device list afterwards. I have included other zwave devices before and they all showed up after adding the node.
Running the latest stable version of domoticz on a pi and using an Aeon Labs USB Z-Stick.
Any help is much appreciated.
Will try to add additional info later.
Re: Fibaro door sensor included as node, not visible in devices.
Posted: Friday 20 May 2016 16:10
by rf646
Anybody?
Posted: Friday 20 May 2016 21:21
by mvveelen
They should appear as FIBARO System FGK101 Door Opening Sensor (if you have the same) after including them. Perhaps you might want to exclude them and include them again, one by one? Or reset the sensors and exclude / include them again?
Posted: Friday 27 May 2016 18:55
by rf646
Thanks for the suggestion. I have already tried excluding and including them and also resetting them and then including again. The weird thing is that the inclusion works fine, only they don't show up in devices afterwards. I've looked through al the devices without filter, but can't find them.
Thanks for any advice in advance.
Posted: Friday 27 May 2016 21:40
by Plaagje
Keep trying, I had to include the door sensor several times before Domoticz included it succesfully
Sent from my Nexus 5X using Tapatalk
Posted: Saturday 28 May 2016 9:31
by rf646
So it did include but did not show up in devices in your case?
Posted: Sunday 29 May 2016 10:13
by gizmocuz
did you try restarting domoticz ?
Re: RE: Re: Fibaro door sensor included as node, not visible in devices.
Posted: Sunday 29 May 2016 22:16
by Plaagje
rf646 wrote:So it did include but did not show up in devices in your case?
I keep including it till is was a success sometimes I had to delete if it was not a success
Posted: Wednesday 01 June 2016 12:26
by rf646
I did try restarting domoticz a couple of times. That didn't work. I will try to add end remove a couple more times than I already have done before. I'll let you guys know if it works. Thanks so far for the suggestions.
Posted: Sunday 14 February 2021 12:56
by BartSr
Allthough this thread is almost five years from now: faced almost same problem. Nodes can be seen but nothing in devicelist. I don"t see the problem has been solved from above messages.
