RFXCOM BOFU Blind how to find 4 digit ID code?
Posted: Saturday 07 May 2016 22:27
by KevinR
Hi ,I have just started with my setup and got varius lighting working well. I am now trying to get my BOFU roller blinds to work, but I need the ID code. I am am using:
RFXtrx433E
Transceiver type = 433.92MHz
Firmware version = 1002
Firmware Type = Ext2
Transmit power = 10dBm
Hardware version = 1.3
Type: T0 Hasta new/RollerTrol,
Unit Code: All
Command: Open
Any suggestions on how to find out the correct ID code would be most appreciated.
Blinds command
Packettype = BLINDS1
subtype = Safy / RollerTrol / Hasta new
Sequence nbr = 62
id2-3 = 0269
Unit = All
Command = Open
Signal level = 0 -120dBm
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 62
response = ACK, data correct transmitte
Re: RFXCOM BOFU Blind how to find 4 digit ID code?
Posted: Sunday 08 May 2016 8:24
by Raspberry Piet
Hi Kevin,
Load firmware Type2 to get the remote ID. (BlindsT0 enabled)
After Domoticz added your Bofu device (Accept new Hardware Devices in settings!) you can load your previous firmware.
I have also a RFLink, send and receive possible!
Works very well with my Bofu blinds!
Re: RFXCOM BOFU Blind how to find 4 digit ID code [RESOLVED]
Posted: Sunday 08 May 2016 17:17
by KevinR
Hi PR, Thanks for the reply.
Using RFXflash.exe I have loaded Type 2 software. Via RFCmngr I set T0 receive and then pressed one of the handset buttons. This returned:
Sequence nbr = 0
id2-3 = BDC2
Unit = 15
Command = Open
Signal level = 8 -56dBm
BDC2 entered into Domoticz and all blind commands working well.
THANK YOU.
Best Regards Kevin
Posted: Sunday 08 May 2016 18:10
by KevinR
Hi RP,
What I meant to say was: DC2 entered into
RFXmngr and all blind commands working well.
So far so good
When entering into Domoticz, I have the hardware item: RFXtrx 433 E, RFXCOM - RFXtrx433 USB 433.92MHz Transceiver, COM3 that I successfully use for my light switches and that I tested the blinds with using RFXmngr.
I created a Switch using this hardware item, but I cannot find a BOFU related item type - What did you use?
Also, having tried all the available 'item type' options they only transmit an 'ON' command, not an 'Open/Stop/Close' command set.
Any ideas what I am doing wrong?
Kevin.
Posted: Sunday 08 May 2016 18:58
by Raspberry Piet
Hi Kevin,
Attach your RFXtrx (loaded with Type2 firmware and with BlindsT0 enabled) to Domoticz instead of RFXmngr.
Do not forget to activate "Accept new Hardware Devices" in Setup/Settings menu.
Then press the buttons of your Bofu remote, it should show up as "RollerTrol, Hasta new" in the Setup/Devices overview.
After it shows in this devices overview you can load the previous firmware for your RFXtrx.
Re: RFXCOM BOFU Blind how to find 4 digit ID code[Blinds Working]?
Posted: Monday 09 May 2016 22:33
by KevinR
Hi RP,
All working, thanks to you.
Much appreciated.
Best Regards
Kevin.
Posted: Tuesday 02 May 2017 2:10
by hammermedia
I have RollerTrol blinds and the Unit # just shows 0 for all the blinds. I'm using an LCD remote from RollerTrol that selects the Unit (specific shade) and it is synced up and works great.
I have flashed Type 2, set to T0. RFXMGR can read the remote 7B46 and control the blinds just fine. It lists the Unit, 1 through 5, for the blind I wish to control.
In Domoticz, I have T0 set. It sees the remote and lists the ID as 7B46 but the Unit shows as 0. Any ideas? I also, changed the Unit to 1 using SQLite and even though it shows correctly in Domoticz it does not control the shade.
This is a fresh install of Domoticz. My SD card crashed after two years. The blinds have been working perfectly for that long. But the reinstall won't show the Unit. HELP!?!?!?!
Posted: Saturday 06 May 2017 1:14
by hammermedia
I just did an update on Domoticz and everything worked again. I'm back up and running 100%.
The whole process for me was.....
Write the old version to a 2 GB SD card
putty to the Domoticz IP .55
user pi
pw raspberry
MUST DO THIS !!!!!
sudo curl -L install.domoticz.com | sudo bash
sudo apt-get update
Add the RFXtrx 433 in hardware.
Use the LCD remote and hit the stop buttons for each of your shades. They will show up in devices.
Go to "Switches" and change the device type to blinds.
