Page 1 of 2
Resol DL2 Datalogger(Vbus)
Posted: Tuesday 03 May 2016 11:51
by MarceldeJongNL
Hi Everybody,
After lurking for quite some time, I decided to register an account and share my newly created script for reading the values out of my solar collector.
I installed a solar collector set this week. The pump is controlled by a Resol DeltaSol® CS Plus http://www.resol.de/index/produktdetail ... sprache/en and I bought a Resol DL2 Datalogger http://www.resol.de/index/produktdetail ... sprache/en
The Datalogger has some nice features to read the current values, save historic values and post them to the VBus.net site.
I wanted to add those values to my domoticz system, so I wrote a Lua to get the values and update my sensors.
As I am fairly new to LUA and JSON, I had some trouble getting the right values from the JSON to the Lua Table and into Variables.
My Solution: Uncomment the print_r on row 71. This will print a nice table in your log, showing the complete table created from the JSON. From there you can find the associated indexes for the values you require.
Create the Dummy sensors you need, in my case "TempCollector", "TempBoilerTop", "TempBoilerBottom", "CurrentPumpSpeed", "TotalPumpTime".
Note their IDX's and add them to the script.
You will need the json.lua from http://regex.info/blog/lua/json. In my case it is in "/home/pi/domoticz/scripts/lua/". Change the path in row 52 for your location.
Important: I configured my DL2 to allow the guest user (unauthenticated) to read live data. If you don't, you have to add the "...live?sessionAuthUsername=admin&sessionAuthPassword=admin" settings to the URL
As stated, I am not expert on LUA or JSON, so if you know a better way to do some actions, please let me know.
--- Function print_r, used for getting the complete table so you can determine wich values to use
function print_r ( t )
    local print_r_cache={}
    local function sub_print_r(t,indent)
        if (print_r_cache[tostring(t)]) then
            print(indent.."*"..tostring(t))
            print_r_cache[tostring(t)]=true
            if (type(t)=="table") then
                for pos,val in pairs(t) do
                    if (type(val)=="table") then
                        print(indent.."["..pos.."] => "..tostring(t).." {")
                        sub_print_r(val,indent..string.rep(" ",string.len(pos)+8))
                        print(indent..string.rep(" ",string.len(pos)+6).."}")
                    elseif (type(val)=="string") then
                        print(indent.."["..pos..'] => "'..val..'"')
                        print(indent.."["..pos.."] => "..tostring(val))
                print(indent..tostring(t))
        print(tostring(t).." {")
        sub_print_r(t,"  ")
        print("}")
        sub_print_r(t,"  ")
    print()
--- Personal Variables
DL2_URL="http://192.168.1.133/dlx/download/live"   ---If guest user doesn't have rights to view live data, you need to add user & password
TempCollectorIDX=188
TempBoilerTopIDX=189
TempBoilerBottomIDX=190
CurrentPumpSpeedIDX=191
TotalPumpTimeIDX=192
JSON = (loadfile "/home/pi/domoticz/scripts/lua/json.lua")()
print("========================================================================================================")
print ("Getting Resol DL2 Data");
   local dl2_data_get=assert(io.popen('curl '..DL2_URL..''))
   local dl2_data = dl2_data_get:read('*all')
   dl2_data_get:close()
   print ("Decoding JSON Resol DL2 Data to Lua Table");
   local lua_value = JSON:decode(dl2_data)
  --- To show all the records from the table in the log, uncomment next row. Used to determine the values you need.
  --- print_r (lua_value)
   print ("Getting interesting Values");
   TempCollector = lua_value.headersets[1].packets[1].field_values[1].value
   TempBoilerTop = lua_value.headersets[1].packets[1].field_values[3].value
   TempBoilerBottom = lua_value.headersets[1].packets[1].field_values[2].value
   CurrentPumpSpeed = lua_value.headersets[1].packets[1].field_values[5].value
   TotalPumpTime = lua_value.headersets[1].packets[1].field_values[7].value
    print("TempCollector=" .. TempCollector)
    print("TempBoilerTop=" .. TempBoilerTop)
    print("TempBoilerBottom=" .. TempBoilerBottom)
    print("CurrentPumpSpeed=" .. CurrentPumpSpeed)
    print("TotalPumpTime=" .. TotalPumpTime)
   commandArray[0]={['UpdateDevice']=''..TempCollectorIDX..'|0|'..TempCollector..''}
   commandArray[1]={['UpdateDevice']=''..TempBoilerTopIDX..'|0|'..TempBoilerTop..''}
   commandArray[2]={['UpdateDevice']=''..TempBoilerBottomIDX..'|0|'..TempBoilerBottom..''}
   commandArray[3]={['UpdateDevice']=''..CurrentPumpSpeedIDX..'|0|'..CurrentPumpSpeed..''}
   commandArray[4]={['UpdateDevice']=''..TotalPumpTimeIDX..'|0|'..TotalPumpTime..''}
resize_Screen Shot 2016-05-03 at 11.27.39.png (35.39 KiB) Viewed 8207 times
resize_Screen Shot 2016-05-03 at 11.44.06.png (46.45 KiB) Viewed 8207 times
resize_Screen Shot 2016-05-03 at 11.44.20.png (210.59 KiB) Viewed 8207 times
Re: Resol DL2 Datalogger(Vbus)
Posted: Saturday 17 September 2016 7:27
by Sandman79
i dowloaded the json.lua file and put in the exact same location on my raspberry pi.
However on line 52 on this file I do not see any option to change the path.
Is it possible to give a little bit more info what you changed exactly? an example?
Posted: Saturday 17 September 2016 9:12
by MarceldeJongNL
You need to change this line to match the location of the file.
Posted: Friday 23 September 2016 17:48
by Sandman79
thx! But sorry i'm a real noob :(
on which location do you place the second script? and how do ou let the scripts run? don't seem to find any info regarding taht on this site .. :s :oops:
Posted: Monday 26 September 2016 8:18
by MarceldeJongNL
No problem Sandman79!
I run the script as a LUA time script, that means it will run every minute.
More info can be found at https://www.domoticz.com/wiki/Events#Lu ... _Interface
You can see what is going using the logging.
Posted: Tuesday 27 September 2016 21:06
by Sandman79
Thx, got it running! (well at least the temp off the top from the collector, the other 9 tempsensors and the heatexchangecounter i'm gonna try and add whenever I find some precious time)
Thx for the guide and the support!
Posted: Wednesday 28 September 2016 8:32
by MarceldeJongNL
Great! Thanks for letting us know!
Posted: Wednesday 28 September 2016 22:10
by Sandman79
Managed to read out almost al my temperatures ... :)
But have some issues reagriding other values:
-> I managed to get results of my relay usage expressed in percentage in the logs of domoticz, however it would not get captured under the utlitydevice i created.
-> I managed to get results of the volume pumped by the pump on relay 1 in the logs of domoticz, however it would not get captured under the utlitydevice i created. I have to say I got the results in the logs as Liters /hour, while the utlitydevice is in Liters per minute. I have to say that in the Resol servicecenter software it is also mentioned in Liters /minute. So a bit sttange here.
-> I did not manage yet to get any of the WMZ (heatquantity) data into my Domoticz-logs. only got an error about a nill value in my logs . :(
Apparently i did not find any data about the running time of my relais in the DL2 (I can find that info in my Resol BX Plus...)
Also The Resol Servicecenter software has an option to display the total volume of fluid displaced in the WMZ controller (heatquantity) but i do not see this working, and i do not find any link to this info in the DL2 datalogger.
Have to query Resol for a few of these things :). But the Relaypercentages and heatquantity measurements must be some small error I hope in this or my code :)
Posted: Friday 02 December 2016 11:15
by DWesthuis
Good morning,
Last week I bought a Resol KM2 module url: http://www.resol.de/index/produktdetail ... sprache/en.
When i login through the web interface of the KM2, i cannot see the values (like posting Sandman79). When i login though vbus.net i can see this values, but seen no options for JSON. Can somebody help me?
Posted: Saturday 01 April 2017 20:27
by hetista
i have connection to the datalogger
but i face problems with coding below
2017-04-01 20:24:19.676 LUA: ========================================================================================================
2017-04-01 20:24:19.676 LUA: Getting Resol DL2 Data
2017-04-01 20:24:21.134 Error: EventSystem: in script_time_boilertemp: /home/pi/domoticz/scripts/lua/json.lua:685: HTML passed to JSON:decode():
2017-04-01 20:23:55.065 Error: Webserver: File '/stylesheets/smoothness/jquery-ui-1.10.3.custom.css': No such file or directory (2)
2017-04-01 20:23:55.066 Error: Webserver: File '/stylesheets/RESOL/style.css': No such file or directory (2)
2017-04-01 20:23:55.068 Error: Webserver: File '/javascripts/jquery-1.10.1.js': No such file or directory (2)
2017-04-01 20:23:55.119 Error: Webserver: File '/stylesheets/smoothness/jquery-ui-1.10.3.custom.css': No such file or directory (2)
2017-04-01 20:23:55.120 Error: Webserver: File '/stylesheets/RESOL/style.css': No such file or directory (2)
2017-04-01 20:23:55.121 Error: Webserver: File '/javascripts/jquery-1.10.1.js': No such file or directory (2)
2017-04-01 20:24:01.082 Error: EventSystem: in script_time_boilertemp: /home/pi/domoticz/scripts/lua/json.lua:685: HTML passed to JSON:decode():
anybody any solution ?
Posted: Wednesday 05 April 2017 22:36
by MarceldeJongNL
When you open the page: http://<DL Ipadres>/dlx/download/live in browser, what do you get?
My result is:
	"language" : "en",
	"headers" : [
		"id" : "00_0010_2211_0100",
		"description" : "VBus 0: DeltaSol CS Plus",
		"channel" : 0,
		"destination_address" : 16,
		"source_address" : 8721,
		"protocol_version" : 16,
		"command" : 256,
		"info" : 0,
		"destination_name" : "DFA",
		"source_name" : "DeltaSol CS Plus",
		"fields" : [
			"id" : "000_2_0",
			"name" : "Temperature sensor 1",
			"unit" : " \u00B0C",
			"unit_code" : "DegreesCelsius"
			"id" : "002_2_0",
			"name" : "Temperature sensor 2",
			"id" : "004_2_0",
			"name" : "Temperature sensor 3",
			"id" : "006_2_0",
			"name" : "Temperature sensor 4",
			"id" : "008_1_0",
			"name" : "Pump speed relay 1",
			"unit" : "%",
			"unit_code" : "Percent"
			"id" : "012_1_0",
			"name" : "Pump speed relay 2",
			"unit" : "%",
			"id" : "010_2_0",
			"name" : "Operating hours relay 1",
			"unit" : " h",
			"unit_code" : "Hours"
			"id" : "014_2_0",
			"name" : "Operating hours relay 2",
			"unit" : " h",
			"id" : "016_1_0",
			"name" : "UnitType",
			"unit" : "",
			"unit_code" : "None"
			"id" : "017_1_0",
			"name" : "System",
			"unit" : "",
			"id" : "020_2_0",
			"name" : "ErrorMask",
			"unit" : "",
			"id" : "022_2_0",
			"name" : "System time",
			"unit" : "",
			"id" : "020_1_1",
			"name" : "Sensor 1 defective",
			"unit" : "",
			"id" : "020_1_2",
			"name" : "Sensor 2 defective",
			"unit" : "",
			"id" : "020_1_4",
			"name" : "Sensor 3 defective",
			"unit" : "",
			"id" : "020_1_8",
			"name" : "Sensor 4 defective",
			"unit" : "",
			"id" : "024_4_0",
			"name" : "Status mask",
			"unit" : "",
			"id" : "028_4_0",
			"name" : "Heat quantity",
			"unit" : " Wh",
			"unit_code" : "WattHours"
			"id" : "032_2_0",
			"name" : "SV Version",
			"unit" : "",
		"id" : "00_0015_2211_0100",
		"description" : "VBus 0: DeltaSol CS Plus => Standard-Infos",
		"channel" : 0,
		"destination_address" : 21,
		"command" : 256,
		"info" : 0,
		"destination_name" : "Standard-Infos",
		"fields" : [
	"headerset_stats" : {
		"headerset_count" : 1,
		"min_timestamp" : 1491424375.784000,
		"max_timestamp" : 1491424375.784000
	"headersets" : [
		"timestamp" : 1491424375.784000,
		"packets" : [
			"header_index" : 0,
			"timestamp" : 1491424374.894000,
			"field_values" : [
				"field_index" : 0,
				"raw_value" : 18.900000,
				"value" : "18.9"
				"field_index" : 1,
				"raw_value" : 33.300000,
				"value" : "33.3"
				"field_index" : 2,
				"raw_value" : 43.400000,
				"value" : "43.4"
				"field_index" : 3,
				"raw_value" : 23.300000,
				"value" : "23.3"
				"field_index" : 4,
				"raw_value" : 0.000000,
				"value" : "0"
				"field_index" : 5,
				"value" : "0"
				"field_index" : 6,
				"raw_value" : 1619.000000,
				"value" : "1619"
				"field_index" : 7,
				"value" : "0"
				"field_index" : 8,
				"raw_value" : 11.000000,
				"value" : "11"
				"field_index" : 9,
				"raw_value" : 1.000000,
				"value" : "1"
				"field_index" : 10,
				"value" : "0"
				"field_index" : 11,
				"raw_value" : 1354.000000,
				"value" : "22:34"
				"field_index" : 12,
				"value" : "0"
				"field_index" : 13,
				"value" : "0"
				"field_index" : 14,
				"value" : "0"
				"field_index" : 15,
				"value" : "0"
				"field_index" : 16,
				"value" : "0"
				"field_index" : 17,
				"value" : "0"
				"field_index" : 18,
				"raw_value" : 1.110000,
				"value" : "1.11"
			"header_index" : 1,
			"timestamp" : 1491424375.284000,
			"field_values" : [
That is where my script is based on.
Posted: Monday 21 August 2017 20:25
by Mace
Just started this weekend to dive into the Domoticz world, so bare with me please.... ;)
I'm trying to get your script running, Marcel, but I get an error message, stating:
Error: EventSystem: in Resol: [string "commandArray = {} ..."]:74: attempt to index local 'lua_value' (a nil value)
Line 74 states:
(the same as in your script)
I've downloaded the required JSON.lua file and stored it in "C:\Apps\Domoticz\scripts\lua\JSON.lua" (I'm running Win2008 Server). I've put C:\\Apps\\Domoticz\\scripts\\lua\\JSON.lua in line 52, as you apparently have to use \\ instead of single \.
Then edited your script in line 41 with my resol url: http://macesolar.via.vbus.net/dlx/download/live=> used the external link, as the internal link won't resolve somehow.
Finally, I made a new sensor in Domoticz, which has IDX21 and assigned this to TempCollectorIDX. Edited out the rest of the sensors for test puposes.
When I run the script, I get the following messages:
2017-08-21 20:13:49.877 dzVents: ========================================================================================================
2017-08-21 20:13:49.877 dzVents: Getting Resol DL2 Data
2017-08-21 20:13:49.904 dzVents: Decoding JSON Resol DL2 Data to Lua Table
2017-08-21 20:13:49.904 dzVents: nil
2017-08-21 20:13:49.904 dzVents: Getting interesting Values
2017-08-21 20:13:49.905 Error: EventSystem: in Resol: [string "commandArray = {} ..."]:74: attempt to index local 'lua_value' (a nil value)
I've googled around, but all I get is that there is an integer or : missing in the code, but as I've just copied your script, that seems strange to me.
Hope you can help this nitwit out.... ;)
Posted: Monday 21 August 2017 20:43
by MarceldeJongNL
Hi Mace,
I see you are using Windows and DZVents. I use my setup on Raspbian and Ubuntu, without DZVents so there might be a difference there.
You could start by changing
to
print_r (lua_value)
to see if there are any values in the array. You can find them in the log.
but according to you log is not. So also try putting
print (dl2_data)
right after:
That way you can check if the (io.popen('curl '..DL2_URL..'')) did work.
Posted: Tuesday 22 August 2017 23:12
by Mace
Thanks for your reply! The 'DZVents' is standard now, I suppose, came with the install.
I already tried the 'print_r (lua value), didn't help.
Added the 'print (dl2_data)', now looks like this:
    print (dl2_data)
Still get the same error... :cry:
Posted: Tuesday 22 August 2017 23:14
by MarceldeJongNL
Since you are on windows, do you have curl available?
Posted: Wednesday 23 August 2017 20:27
by Mace
I do now.... ;)
Posted: Wednesday 30 August 2017 22:36
by Mace
Still working on this. Decided to do a fresh install on Raspberry, Windows gave me more problems in different area's too.
I've got the script running, put the code into an 'event' and in te logging, I can see the correct values coming inn:
2017-08-30 22:29:01.302 LUA: TempCollector=14.9
2017-08-30 22:29:01.302 LUA: TempBoilerTop=74.5
2017-08-30 22:29:01.302 LUA: TempBoilerBottom=26.9
2017-08-30 22:29:01.302 LUA: CurrentPumpSpeed=0
2017-08-30 22:29:01.302 LUA: TotalPumpTime=6397
Problem I now have that when I assign the virtual sensors, I get values of 0....
BTW: I used the already available JSON.lau and the one you mentioned, no difference.
Hope you can help me!
Posted: Wednesday 30 August 2017 23:17
by MarceldeJongNL
Wise choice! You won't regret is.
Your json.lua is fine, since you are getting values now.
Did you see this part in the guide?
and did you use them here?
Maybe you can post your complete script here?
Posted: Thursday 31 August 2017 21:01
by Mace
I did create the sensors, but I mistakenly filled the IDX numbers of the hardware in the file, not the IDX numbers of the created devices....Works like a charm now!!!
Thanks for your help!
PS: Forget the PM I send you just before this.... ;)
Posted: Saturday 02 September 2017 0:38
by MarceldeJongNL
You are welcome, enjoy!
