Hello All,
I'm really new in the domoticz world so i will describe what i have first and then what i want to do :
what i have :
software : Domoticz 3.4834 from the SD card image
hardware : Raspberry PI3 + Razberry zwave me card.
zwave products : Fibaro door sensor FGK101 + Fibaro FGD-212 Dimmer 2 + ZIPATO (VISION) ZP3102+
project :
- Temperature & humidity:
I want to be able to collect Temperature + humidty in 5-6 rooms on an accurate basis. and probably control home heating system
-Luminosity:
same here but less rooms mostly in my living room where we spend most of the time i nroder to control light dimming
- motion detection:
same 5-6 rooms for security reason and 2 for light control
The thing is if i can use zwave hardware it will be great but from what i see on the forum both Fibaro FGMS 001 - ZW5 and Aeotec ZW100 mutlisensor 6 have temperature, humidy and Lux report issues like not reporting on regular basis.
the thing is i would liek to have like a 10-15 minutes report for temp, humidity and lux data.
What do you recomand with my domoticz version ? i can go with RFXccom adapter also as in the futur i will control my SOmfy sun blind.
PS: in case admin see this please remove my post under suggestions topics as i did a mistake .. sry
thx by advance for your comments
Flo
Requesting help to move forward in my project
Kerneldomoticz
- Domoticz version: 3.5248
