Possible to create 'user variable' within lua using "devicename" and openurl?
SoerenBM
Domoticz version: 3.5169
Post by SoerenBM »
Hi everyone,
I have a lot of virtual devices that I need to create a user variable for (for use with this script http://domoticz.com/forum/viewtopic.php?f=23&t=7512), but I would like to avoid to create them manually so I'm trying via LUA but am not able to get it to work:
Domoticz_Devicename = 'Test Switch'
(devicechanged[''..Domoticz_Devicename..''] == 'On') then
    if(uservariables[''..Domoticz_Devicename..''] == nil) then
    commandArray['OpenURL'] = 'http://192.168.10.11:8080/json.htm?type=command&param=saveuservariable&vname='..Domoticz_Devicename..'&vtype=2&vvalue=1'
If I change vname='..Domoticz_Devicename..' to a hardcode vname like vname=TestSwitch it is working fine.
Just figured out the issue is because of the 'blank' in Domoticz_Devicename
Are there a way to work around this - as it is possible to create user variables manually with 'blanks' in the name.
Thanks.
BR Søren
georgesattali
Re: Possible to create 'user variable' within lua using "devicename" and openurl?
Post by georgesattali »
Yes, it is possible if you replace the blank by a "+" to conform to url encoding :
noBlankDomoticz_Devicename = string.gsub(Domoticz_Devicename, " ", "+")
commandArray['OpenURL'] = 'http://192.168.10.11:8080/json.htm?type=command&param=saveuservariable&vname='..noBlankDomoticz_Devicename..'&vtype=2&vvalue=1'
See you,
GD
SoerenBM
Post by SoerenBM »
Thank you, GD.
Worked perfectly :D
BR Søren
