[SOLVED] debug commandArray
jmleglise
Domoticz version: 2022.1
Post by jmleglise »
Does anybody know how to print the content of commandArray ?
In a very big LUA script, I prepare a lot of command in commandArray like this :
	commandArray[1]={['device']='Off'}
	commandArray[2]={['device'']='Stopped AFTER 5'}
	commandArray[3]={['device']='Off AFTER 300'}
	commandArray[4]={['deviceX']='Off'}
But I have a bug, and I would like to check what I finally have in commandArray
Last edited by jmleglise on Wednesday 27 April 2016 21:53, edited 1 time in total.
My script : https://github.com/jmleglise
RFXTRX433E: Blind Somfy RTS, Portal Somfy Evolvia, chacon IO, Oregon, PIR sensor PT2262
My Last project : Location de vacances a Ouistreham vue mer
KMTronic USB relay
Chinese Z-WAVE: Neo CoolCam
jvdz
Domoticz version: 4.107
Re: debug commandArray
Post by jvdz »
This should work at the end of the script:
for i, v in pairs(commandArray) do
   print('### ++++++> Device Changes in commandArray: '..i..':'..v)
EDIT:this works for the shown format:
commandArray[2]={['device']='Stopped AFTER 5'}
commandArray[4]={['device']='Off'}
   print('### ++++++> Device Changes in commandArray: '..i..':' .. v["device"])
Jos
jmleglise
Post by jmleglise »
Thank you. You put me on the right way !
As my commandArray is filled with different device like this :
commandArray[1]={['motion']='On'}
commandArray[2]={['temp']='Off'}
commandArray[3]={['door']='On'}
the complete solution is :
	for namedevice, t in pairs(v) do
		print('### ++++++> Device Changes in commandArray: '..i..namedevice.. v[namedevice])
I did not understand everything. But that works !
KMTronic USB relay
jvdz
Post by jvdz »
Just to make this work for both formats of responses in commmandArray:
commandArray["test"]='Off'
commandArray["test3"]='Off AFTER 300'
commandArray[1]={['tdevice']='Off'}
commandArray[2]={['adevice']='Stopped AFTER 5'}
commandArray[3]={['cdevice']='Off AFTER 300'}
commandArray[4]={['bdevice']='Off'}
print('### ++++++> Device Changes in commandArray: ')
   if type(v) == "table" then
		  print('### '..i.."="..namedevice.."->".. v[namedevice])
	  print('### '..i.."->".. v)
Jos :)
