1-wire resistor choice and wire size Topic is solved
Moderators: fantom, leecollings
n1c0l45
Domoticz version: V3.4834
Post by n1c0l45 »
I plan to replace most of my temp RF sensors with wired ones. I would like to do this bus
The orange part is optional... i would like to do it (freezer & fridge sensors) but they may get things too complcated?
So the bus has a lenght of 14,1m and a weight of 22.9m (optional version) or 18.9m (short version). I also plan to use 3 wires (not a parasite setup)
My three questions:
1- What wire size should be best for this? (I can get nearly all type of cable for free at work, so if there is something better than network cable...) :lol: :lol:
2- Is there formula or else to calculate the good size of the resistors (& capactiors?) and where it should be best to put them?
3- Is there a test that i can do with an oscilloscope to test my setup to be sure to get things working nicely?
thank you guys for your help and sorry for my english
Nicolas
n1c0l45
Re: 1-wire resistor choice and wire size
Post by n1c0l45 »
No ideas?
Marci
Domoticz version: 3.8153
Post by Marci »
Dunno about electronically correct but I've done the above on cat5 with 4.7k resistors... all works fine.
n1c0l45
Post by n1c0l45 »
Thanks for your answer!
How many sensors have you got? And what length?
cul8r
Post by cul8r »
I have 9 sensors, length appr.15 m and weigth appr. 35 m with 4.7 kOhm pull-up and in parasitic mode with no problems. (Using Raspberry GPIO and kernel support). I have a second installation close to a compressor and in that case it is only 4 m length and 2 sensor, was force to go to 1.2 kOhm pull-up.
Maxim recommends max length/weigth 200 m with pull-up of 1 kOhm, also if you have many stubs (branches) they could cause problem due to impedance mismatch and solution is to have 100-150 Ohm in serie where the data line where the branch begins.
For cables in the range 0-30 m it is not critical, but using a CAT5 cable is to be in the very safe side. I am using a mixture of of telephone cables (0.15 mm2) and even using 2 spare pair of the alarm installation! (20 pairs, 0.2 mm2 cable).
There is a very good application note at Maxim:
https://www.maximintegrated.com/en/app- ... mvp/id/148
/C
n1c0l45
Post by n1c0l45 »
Thanks for the answer!
I have already red the maxim note but there is no informations on resistors values
n1c0l45
Post by n1c0l45 »
cul8r wrote:I have 9 sensors, length appr.15 m and weigth appr. 35 m with 4.7 kOhm pull-up and in parasitic mode with no problems. (Using Raspberry GPIO and kernel support). I have a second installation close to a compressor and in that case it is only 4 m length and 2 sensor, was force to go to 1.2 kOhm pull-up.
/C
Do you have just one 4.7k resistor?
So if I understand well, I use a 4.7k between 3.3v and data line near the gpio, and a 100ohm resistors on the data line of each branch?
cul8r
Post by cul8r »
Yes, only one 4.7 kOhm from 3.3 to GPIO/dataline at the Rasberry connector.
The 100 Ohm is only if you have problems with impedance mismatch, and in your case should not be a problem with that. With your topography but with much longer cables and having problem, I would try 100 Ohm at the start of the "3 m" branch.
The application note states that a FET driver and 1 kOhm pull-up is good for 200 m length/weigth, the 4.7 kOhm value is a standard value recommended in Raspberry 1-wire applications.
cul8r
Post by cul8r »
By the way, this is the board I made for my application!
/C
GPIO_2-O-4-IN_1-WIRE E.pdf
(47.85 KiB) Downloaded 791 times
n1c0l45
Post by n1c0l45 »
Thank you for all of that!
