Dear all,
Ideally I would like to integrate my alarm system (Marmitek Proguard 800) status into Domoticz, so I can act upon.
I have two idea's but some thought on how these can be easily incorporated are most welcome.
1) Use the programmable relais. The proguard has a programmable relais which can set 220V to a contact. Is there a simple way to integrate this into Domoticz on a Raspberry Pi ?
2) The Proguard can send an X10 "on" command via the powermains, how could I get Domoticz to pick up this X10 signal (not via RF)? Is there a way to integrate my unused CM15Pro for this purpose?
Regards, Jeroen
Integrating Marmitek Proguard 800 status into Domoticz?
- Domoticz version: 2023.2
Re: Integrating Marmitek Proguard 800 status into Domoticz?
This works now. Domiticz "listens" to my Proguard 800 alarm system via the CM15Pro Mochad interface.
I have set-up Mochad as descriped in the Wiki. https://www.domoticz.com/wiki/X10_devices,_CM15_Pro.
Next, I added Mochad to the Hardware in Domoticz (locahost and port 1099). This is already sufficient for Domoticz to recognize devices.
In the Marmitek Proguard 800 (with a X-10 module) I set HA Module 16 to "On" when alarm is activated. And I set HA Module 15 to "On" in case of an alarm.
So now, when I turn on my alarm, Domoticz sees X10 module being switched on. If I trigger the alarm, Domoticz sees X10 device 15 being turned on. Now I can act upon these events. <to be done>.
Ideally I want to trigger different timers when the alarm is on and off.
Some more advancement on integrating Proguard800, hoping it might be useful for some of you.
Now I managed to "integrate" the Proguard 800 motion sensors. The sensors itself I believe do send an encrypted signal and are not picked up by the RfxCOM. So to date I did not manage to create events based on motion detection.
Below is a work-around.
In your Proguard 800 create a "dummy" HA module (for instance #12). For this module in the proguard set the "On with Zone" to a value. E.g. On/Off for a door contact, or 30 sec for a motion sensor.
If these zones now get triggered, a new device shows up in the Domoticz device list, and can be added (I made them hidden). I then created an event that if the doors to the garden are open, it turns off my EvoHome heating system.
Another event I created, turns on the light in the Hall for 1 minute if motion is detected.
It works pretty good, however not perfect, as in some exceptional cases the X10 signal on the power-line does not get picked up by my CM15PRo. Do not know why.
Hi Thank you very much for your description.
Did you find a solution to catch the event when the alarm is disabled ?
Regards.
Fabrice.
Regards.
Fabrice.
Hi Fabrice,fpoulet wrote:Hi Thank you very much for your description.
Regards.
Fabrice.
What I did was change the setting for the associated HA module in the proguard to On/Off (so do not use the pulse option). You now have a toggle switch which you can pick up in domoticz.
Unfortunately it does not work all the time. Switching the alarm off, does not always get picked up. I Blaim it to a weak X10 signal from the proguard to the CM15Pro. Any ideas here more than welcome.
Switching the alarm on, works perfectly.
Hope this helps.
Jeroen
Verzonden vanaf mijn iPad met Tapatalk
Hi Jeroen,
Thanks a lot for your help.
I finaly reach to make all working perfectly.
I can c now if the alarm is armed or unarmed.
I have an event on intrusion when alarm is armed.
I have events for each zone on detection
In my case i'm using Jeedom, but all explain in this thread is correct for domoticz also.
Just one think i have discovered. There is a bug somewhere in Mochad or the plugin in Jeedom.
It is not allowed to use addresses greater than A9. Using 2 numbers result always to use the module A1
In conclusion monitoring the marmitek Proguard 800 is 100% doable but impossible to control using the x10
Regards,
Fabrice
Regards,
Fabrice
Dear all,
As the X10 solution was not very reliable, I managed to use the programmable switch in the Proguard.
I connected a zwave wall switch to the power supply of my alarm, and the white switch wires to the programmable PRU contact of the Proguard.
Using: HAC01 – IN-WALL REMOTE MODULE from Everspring (eminent has the same).
In the zwave group editor I linked this switch to a “dummy” zwave on/off ( dummy as I only use the switch to follow the status of my alarm).
In domoticz in need to enable polling for the on/off switch, as somehow the a status change made the micro switch does not give an status update.
Let me know if you need more details.
Jeroen
Jeroen
