How to scrape humidity only from wtgr800?
Posted: Sunday 24 April 2016 10:51
by BarryT
Good Morning,
is it possible to only scrape the "humidity" from a WTGR800 sensor?
i can't find it on the forum, nor the internet.
I want to make a irrigation system with it, so need some (variable?) values in blocky to turn on/off a (virtual switch) watervalve.
Re: How to scrape humidity only from wtgr800?
Posted: Sunday 24 April 2016 10:59
by georgesattali
you may find examples herehttps://www.domoticz.com/wiki/Smart_Lua_Scripts
I use :
      smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues["TempHum1"]:match("([^;]+);([^;]+)")
      debug("-- Irrigation ==> [TempHum1] - Soil Temperature: " .. smoistsensorTemp .. " ")
      debug("-- Irrigation ==> [TempHum1] - Soil Humidity: " .. smoistsensorHumidity .. " ")
See ya, GD
Posted: Sunday 24 April 2016 11:04
by BarryT
Hi George, i've looked into there but that's not very easy :(
2016-04-24 11:03:01.884 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_hum.lua: /home/pi/domoticz/scripts/lua/script_device_hum.lua:2: attempt to call global 'debug' (a table value)
Thank you..
Posted: Sunday 24 April 2016 11:07
by georgesattali
Sorry,
debug is a function of mine, you can replace it with print to see the values in "Setup / Log" of Dz.
Posted: Sunday 24 April 2016 11:32
by BarryT
2016-04-24 11:31:05.661 (rflink) Temp + Humidity (Grondvochtigheid)
2016-04-24 11:31:05.856 LUA: -- Irrigation ==> [TempHum1] - Soil Temperature: 17.0
2016-04-24 11:31:05.856 LUA: -- Irrigation ==> [TempHum1] - Soil Humidity: 99
okay, it seems that it prints the output, but now i want it to an (virtual) device so i can use it in blocky!
thanks :D
Posted: Sunday 24 April 2016 11:44
by BarryT
Why is it so hard to export a variable value to an (virtual) device, so i can switch on/off things when a value is to low or to high..?
maybe i need to work with variables?
anyway, this drives me really crazy.
working with temperatures in blocky is no problem at all, but for humidity it doesnt work :(
Posted: Sunday 24 April 2016 15:53
by woody4165
This is the result if you
where xxxxxx is the idx number of my wtgr800 connected via RFLink
   "ActTime" : 1461505766,
   "ServerTime" : "2016-04-24 15:49:26",
   "Sunrise" : "06:17",
   "Sunset" : "19:59",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 0,
         "CustomImage" : 0,
         "Data" : "22.0 C, 51 %",
         "Description" : "",
         "DewPoint" : "11.40",
         "Favorite" : 1,
         "HardwareID" : 15,
         "HardwareName" : "RFLinkB3C",
         "HardwareType" : "RFLink Gateway USB",
         "HardwareTypeVal" : 46,
         "HaveTimeout" : false,
         "Humidity" : 51,
         "HumidityStatus" : "Comfortable",
         "ID" : "xxxx",
         "LastUpdate" : "2016-04-24 15:48:55",
         "Name" : "TempExt",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "SubType" : "WTGR800",
         "Temp" : 22.0,
         "Timers" : "false",
         "Type" : "Temp + Humidity",
         "TypeImg" : "temperature",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "xxx"
   "status" : "OK",
   "title" : "Devices"
In my Frontpage.html (by G3rard) I just grab the field "Humidity" and "Temp" to get a number only value.
Posted: Sunday 24 April 2016 16:40
by Toulon7559
@BarryT
Just wondering about your question:
1) Is the humidity-sensor of wtgr800 showing itself under Dashboard/ Devices (possibly in combination with Temperature)?
2) Subsequently (when activated under Devices), does the humidity-sensor of wtgr800 then show itself under the list of 'blocky'-elements?
List viewed according to sequence Setup > Events > Devices > Humidity
Posted: Thursday 28 April 2016 17:32
by BarryT
Toulon7559 wrote:@BarryT
1) Yes it is showing itself, indeed with combination temperature.
I just want to have them as "single" values in a dummy.
2) Yes i seen them in blocky, ofcourse as single ones (temp and humidity).
I just want to have the values as single ones.
I have many devices, and the temperature and humidity takes up much space in the (index) layout of my mobile device.
