How to scrape humidity only from wtgr800?
BarryT
- Domoticz version: 2024.3
Good Morning,
is it possible to only scrape the "humidity" from a WTGR800 sensor?
i can't find it on the forum, nor the internet.
I want to make a irrigation system with it, so need some (variable?) values in blocky to turn on/off a (virtual switch) watervalve.
georgesattali
Re: How to scrape humidity only from wtgr800?
you may find examples herehttps://www.domoticz.com/wiki/Smart_Lua_Scripts
I use :
See ya, GD
I use :
smoistsensorTemp, smoistsensorHumidity = otherdevices_svalues["TempHum1"]:match("([^;]+);([^;]+)")
debug("-- Irrigation ==> [TempHum1] - Soil Temperature: " .. smoistsensorTemp .. " ")
debug("-- Irrigation ==> [TempHum1] - Soil Humidity: " .. smoistsensorHumidity .. " ")
BarryT
Hi George, i've looked into there but that's not very easy
2016-04-24 11:03:01.884 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_device_hum.lua: /home/pi/domoticz/scripts/lua/script_device_hum.lua:2: attempt to call global 'debug' (a table value)
Thank you..
Thank you..
georgesattali
Sorry,
debug is a function of mine, you can replace it with print to see the values in "Setup / Log" of Dz.
BarryT
2016-04-24 11:31:05.661 (rflink) Temp + Humidity (Grondvochtigheid)
2016-04-24 11:31:05.856 LUA: -- Irrigation ==> [TempHum1] - Soil Temperature: 17.0
2016-04-24 11:31:05.856 LUA: -- Irrigation ==> [TempHum1] - Soil Humidity: 99
okay, it seems that it prints the output, but now i want it to an (virtual) device so i can use it in blocky!
thanks
thanks
BarryT
Why is it so hard to export a variable value to an (virtual) device, so i can switch on/off things when a value is to low or to high..?
maybe i need to work with variables?
anyway, this drives me really crazy.
working with temperatures in blocky is no problem at all, but for humidity it doesnt work
woody4165
This is the result if you
In my Frontpage.html (by G3rard) I just grab the field "Humidity" and "Temp" to get a number only value.
where xxxxxx is the idx number of my wtgr800 connected via RFLink
"ActTime" : 1461505766,
"ServerTime" : "2016-04-24 15:49:26",
"Sunrise" : "06:17",
"Sunset" : "19:59",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 0,
"CustomImage" : 0,
"Data" : "22.0 C, 51 %",
"Description" : "",
"DewPoint" : "11.40",
"Favorite" : 1,
"HardwareID" : 15,
"HardwareName" : "RFLinkB3C",
"HardwareType" : "RFLink Gateway USB",
"HardwareTypeVal" : 46,
"HaveTimeout" : false,
"Humidity" : 51,
"HumidityStatus" : "Comfortable",
"ID" : "xxxx",
"LastUpdate" : "2016-04-24 15:48:55",
"Name" : "TempExt",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "WTGR800",
"Temp" : 22.0,
"Timers" : "false",
"Type" : "Temp + Humidity",
"TypeImg" : "temperature",
"Unit" : 0,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "xxx"
"status" : "OK",
"title" : "Devices"
Toulon7559
- Domoticz version: <2025
@BarryT
Just wondering about your question:
1) Is the humidity-sensor of wtgr800 showing itself under Dashboard/ Devices (possibly in combination with Temperature)?
2) Subsequently (when activated under Devices), does the humidity-sensor of wtgr800 then show itself under the list of 'blocky'-elements?
List viewed according to sequence Setup > Events > Devices > Humidity
BarryT
1) Yes it is showing itself, indeed with combination temperature.Toulon7559 wrote:@BarryT
I just want to have them as "single" values in a dummy.
2) Yes i seen them in blocky, ofcourse as single ones (temp and humidity).
I just want to have the values as single ones.
I have many devices, and the temperature and humidity takes up much space in the (index) layout of my mobile device.
